Hardinge TT Tapping Head
Results 1 to 14 of 14
    Jan 2013
    Erie, CO
    183
    34
    17
    Default Hardinge TT Tapping Head
    I pick up a TT tapping head, and have been looking around for some instructions and can not find much. I figured I would read up on it before trying the thing out. Anyone have info on setting these things up.
    Oct 2010
    Oregon
    5,311
    4795
    1952
    TT holders are great! They're basically the internal thread equivalent to acorn die holders, but nicer to use.
    There are really only two things to set up on the holder itself. You need the correct TT collet for the tap size you're going to use, and you need to make sure the TT holder is set for right-handed or left-handed to match the tap. There is a pawl and a spring visible in the front, black part of the holder in the lower left of the attached photo. The pawl needs to be flipped to the R or L side (stamped on the body) and the spring needs to be moved to the same side so it forces the pawl outward.
    Assuming you're using the TT holder on a small turret lathe (like the Hardinge DSM-59), you want the spindle turning in the proper direction for the tap to cut, advance the turret until the tap starts cutting, then continue with very slight feed pressure until you reach the desired tap depth. Then stop advancing the turret. The tap will continue to feed a little further, disengaging the dogs that lock the two parts of the holder and allowing the front, black part of the holder to spin with the spindle. Reverse the spindle. On the DSM-59 do not be shy about plugging directly from forward to reverse. The pawl will immediately lock up the holder and the tap will start unscrewing itself from the work. Retract the turret with slight feed pressure.
  3. Likes Stradbash liked this post
    Feb 2006
    Indiana
    13,200
    727
    4124
    I have several TT holders and a bunch of TT collets. One problem I have seen when I got a used TT holder is that the 1/8" dowel pin that keeps the collet from spinning in the holder is sometimes pushed back in its hole, preventing it from functioning. It is possible to take the holder apart and drive the pin back to its proper position. When installing a collet, the slot in the collet back has to engage the pin. If the collet is placed in the holder incorrectly and the nut is then tightened, the pin is pushed back in its hole.
    Larry
  5. Likes sfriedberg, Stradbash liked this post
  6. #4
    Jan 2013
    Erie, CO
    183
    34
    17
    When I remove the nut from the collect side, I do see the pin sticking up. To check the dog do I remove the allen bolt to get it to separate?
    Mark
  7. #5
    Oct 2010
    Oregon
    5,311
    4795
    1952
    I'm not near the shop right now, but if I recall correctly, the two main parts are bolted together through the hollow shank. Undo that bolt and it comes apart.
    BTW, see the three raised dogs on the face perimeter of the black part, and one corresponding dog down inside the steel-colored part on the other side of the spring? The height of those dogs is how far the tap will continue to feed once you stop advancing the holder. Alternatively, that's the "window" of tolerance you have to match the tap self-feeding action with the turret feed.
  8. Likes Stradbash liked this post
  9. #6
    Apr 2005
    Michigan
    358
    1363
    59
    That’s correct! Remove the long Allen head cap screw from the back and it comes apart, including three springs and some bearing balls. They are easy to clean and device.
  10. #7
    Jan 2013
    Erie, CO
    183
    34
    17
    Thanks guys!
  11. Likes Stradbash liked this post
  12. #8
    Aug 2010
    Illinois
    101
    19
    I bought a used TT holder. It's missing the spring that goes inside, as seen in the photo above. Anyone have dimensions? I just as soon buy a stock spring from McMaster.
  13. #9
    Apr 2005
    Michigan
    358
    1363
    59
    If I recall correctly, they’re not very expensive from Hardinge. Buy all three while you’re at it!
  14. #10
    Aug 2010
    Illinois
    101
    19
    Is email a valid means of contacting them for parts? No response, yet.
  15. #11
    Apr 2005
    Michigan
    358
    1363
    59
    Apparently Hardinge no longer sells parts directly, but rather through other companies. I don't recall who handles parts and support for Illinois. I'm in Michigan and dealt with Gosiger, and they were good and helpful, but it's been a few years. That said, Hardinge should at least respond to your inquiry with the appropriate contact information.
    Gosiger | Serious Solutions
  16. #12
    Apr 2005
    Michigan
    358
    1363
    59
    This is the information I provided Gosiger and it worked.
    For hardinge TT tapping heads I need the following parts, which comes down to all 3 springs in each head X 4. I think I have provided good part numbers, but cannot be sure. They were numbers found on bags containing the right parts, but I do not have a Hardinge parts list for these tools.
    #6 0009859 Small spring to go behind pawl apx. .6” long X .12” OD
    # ST 8872 Large diameter spring to provide float apx. .5” long X .86” OD
    # ST 8101 Spring that goes into the shank. Bolt passes through it. apx. 1.5" long X .365 OD
    And the email that worked for me in December of 2016;
    [email protected]
  17. Likes dieselpilot liked this post
  18. #13
    Sep 2003
    South Carolina
    910
    85
    Within the last year I've bought several parts direct from Hardinge Elmira. If you can figure out the part no, their site will show prices and availability. I've always called to order and their phone service was excellent. My understanding is that they've recently brought most of their parts service back in-house.
  19. Likes Stradbash liked this post
  20. #14
    Aug 2010
    Illinois
    101
    19
    Thanks. The P/N come up in the Hardinge shop so I'll give that a try.
  21. Likes Stradbash liked this post
