Have you seen this Bridgeport attachment
Results 1 to 6 of 6
    Jan 2013
    11
    Default Have you seen this Bridgeport attachment
    Just picked up a bridgeport mill.
    It has an interesting dial indicator on the Y axis. I got it cleaned up and working pretty nice however I'm not quite sure how it operates.
    I'm pretty sure there are some parts missing. Thinking there has to be an adjustable rod to lay in the V grove or perhaps a collection of
    fixed length rods.
    Has any one seen this attachment and can identify? Whats it's official name? Not found any hints on google.
    Thank you
    Feb 2007
    Philly, Pa.
    367
    67
    34
    Early digital readout for more accurate hole locations.
  3. Likes HWElecRepair liked this post
    Mar 2011
    Geneva Illinois USA
    6,273
    2712
    2424
    Very common on the older jig bores.
    Tom
    Oct 2011
    West-Central Illinois, USA
    1,281
    2049
    583
    Yes, they’re for end measuring rods reading in tenths. I suppose ID mics would kinda work (to .001”) if you made some sleeves for the troughs.
    As an aside, (may have been stated here before) it was customary for the red mic head to go in the “Y” trough and the green one in the “X” (everyone’s right or wrong the same way). Said otherwise by an old German it’s “Red pecker → Green thumb” as to where the mics were close to which part of you while working...
    Good luck,
    Matt
    Attached Thumbnails Attached Thumbnails end_measure_rods_pw.jpg   idmic_endmeasure.jpg
  6. Likes M.B. Naegle liked this post
  7. #5
    Feb 2011
    2,277
    1717
    971
    How does it mount to the knee? Our 1959 Bridgeport had a T-slot down there that we took off when we set it up with a DRO. I always thought it was just for mounting travel limits, but maybe it's part of one of those?
  8. #6
    Oct 2011
    1,281
    2049
    583
    I think both the optical and the end measuring system went on more or less the same way. There were 2 spot faced areas with tapped holes on the knee you could clamp most anything to.
    They also had a different way to lock the saddle & table than the usual clamps if you wanted (reed clamp I think they called them).
    This is from a 1969 catalog below showing the end measure option.
    Good luck,
    Matt
