Help identify this Hardinge part
Results 1 to 8 of 8
    Aug 2013
    Worcester County, Massachusetts
    972
    372
    128
    Default Help identify this Hardinge part
    Anybody know what this is for?
    It appears to be some sort of offset adapter.
    The handle moves the top part so the socketed hole is not inline with the axis of the shank.
    It is spring loaded, and the set screws can be adjusted to limit travel or fix the top part in position.
    I vaguely recall seeing one of these some wheres but cannot recollect what it was on.
    Steve.
    Sent from my LM-G900TM using Tapatalk
    Jul 2006
    Hillsboro, New Hampshire
    10,889
    2539
    7626
    For internal threading, or cutting a circlip groove?
  3. Likes sfriedberg, Billtodd liked this post
    Jun 2020
    South Carolina
    62
    24
    16
    That’s for boring and recessing on a hand screw
  5. Likes neilho liked this post
  6. #4
    Aug 2013
    972
    372
    128
    Quote Originally Posted by upm2019 View Post
    So it sticks in a hole on the turret on a. Model like this?
  7. #5
    Oct 2010
    Dewees Texas
    2,810
    29
    867
    That is correct it is a recessing tool. Turret mounted when used. I have one like it with out the rust.
    I take it back not the same as mine. The travel on this one appears to be derived from pivoting mine has a straight feed on a dove tail.
  8. #6
    Aug 2013
    972
    372
    128
    Quote Originally Posted by FredC View Post
    Yes, it pivots. Now that i know the type of lathe it was used on, i was able to do more research. I read in a thread where a guy called it a "swing tool". Another guy said recessing tool.
    Steve.
  9. Likes 1yesca liked this post
  10. #7
    Aug 2013
    972
    372
    128
    At the 8:52 mark in this guys video he shows it and explains its use.
    Hardinge DSM-59 - YouTube
  11. #8
    Oct 2010
    Oregon
    5,456
    5093
    2035
    Quote Originally Posted by stevewatr View Post
    Apples and oranges, both correct.
    There are several clever ways of activating spring-loaded tools on a turret lathe. "Swing" is one, and "bump" is another. Pivots and slides, basically. The activating force might be taken from a manual lever, or from pushing it against the headstock (or other fixed reference), or by pushing against it with the cross-slide.
    Not all spring-loaded turret tools are recessing tools, but most of them do have some character of "getting around behind an overhang".
  12. Likes stevewatr liked this post
