HLV Compound Angle for General Turning
Results 1 to 14 of 14
    Jan 2013
    Erie, CO
    174
    30
    16
    Default HLV Compound Angle for General Turning
    With NSPowerlifter post on eccentric pins breaking, I found myself wondering about wear on the base of the compound. And how angling the compound might cause the wear factor to increase on the bottom of the compound.
    For general turning what angle is your compound set at?
    For threading the manual calls for 60 degrees, which works great for retracting compound. I find myself using the compound slide for a lot general turning, and keep my compound at 45 degrees. It great for cutting up to a shoulder and not running the tool back over the surface you just cut. I feel like it more accurate for me then retracting the crossslide.
    Jul 2007
    UNITED KINGDOM
    4,932
    2737
    2405
    I stick with parallel to the bed for general turning. I find that I don't get marking of the work when winding the carriage back unless the work is too flexible. For threading I use 63°, because that's 7 steps on the Multifix tool-post to bring the tool back to the right angle.
  3. Likes Jersey John liked this post
    Sep 2003
    South Carolina
    907
    83
    I frequently turn with the compound swiveled 30 deg from parallel to the bed to achieve 1/2 reduction of Y axis infeed compared to compound infeed. Reduction in part diameter is direct reading of compound dial.
    May 2009
    Canandaigua, NY, USA
    2,934
    145
    1327
    I have better things to think about. I put it where I need to for threading and wherever I feel like for anything else, usually where it was when threading.
    Mar 2009
    5,413
    98
    1027
    Always return parallel to bed after threading.
    Aug 2019
    94
    9
    12
    Perpendicular to the bed puts my crossfeed and compound controls too close together. Past 50 degrees makes the compound conflict with my tailstock. 30-40 degrees is my normal position, until I need it to cut a specific taper angle.
  8. Likes Red James liked this post
  9. #7
    Jan 2013
    Erie, CO
    174
    30
    16
    Typically I use 45 degrees unless I’m threading. Reading that one post got me wondering if using the compound all the time at an angle can speed up the wear factor. I already resurfaced the bottom of my compound once, plus I know my lathe been rebuilt once.
  10. #8
    Mar 2009
    5,413
    98
    1027
    Sometimes the compound number dial does not turn with the hand crank. It looks like an easy adjustment to tighten things up. Isn't that easy over here. Have not had consistent results.
    After a little fussing with the nut under the crank the number dial turns, but my method has no procedure just luck.
  11. #9
    Sep 2009
    Apex, NC
    1,515
    750
    Quote Originally Posted by rons View Post
    Not to hijack the thread, but the smallest piece of debris or nick on the plate on faces of the dial assemblies will cause a problem. I also put a second thin "locknut" on those handle/dial nuts. I put a few drops of mineral spirits on the dials/plates periodically, then lubricate them with spindle oil to keep from getting gunked with old oil.
    Also, tapped two holes in the end of the compound to retain two metal strips which hold a strip of flexible rubber apron that keeps debris off the compound slides.
    Seems that most wear on the bottom of the compound would be caused by folks not bothering to clean off or lubricate the surface before rotating them, and/or cranking them around while tightened, and standing on the locking pin. These are not hogging geared lathes....
  12. Likes Stradbash liked this post
  13. #10
    Jul 2007
    UNITED KINGDOM
    4,932
    2737
    2405
    The correct adjustment is to tighten the knurled brake screw in the face of the dial. If that isn't there any more, make one to fit.
  14. #11
    May 2015
    UNITED KINGDOM
    1,272
    378
    358
    Personally I return the compound to zero (parallel to bed) after threading or applying a small taper.
    John
  15. Likes Mark Rand liked this post
  16. #12
    Mar 2009
    5,413
    98
    1027
    Quote Originally Posted by Mark Rand View Post
    The knurled screw is there and gently tightened but the stuff stated in post #8 still happens. I'm going to look into it today.
  17. Likes Mark Rand liked this post
  18. #13
    Oct 2010
    Moscow,Idaho,USA
    1,253
    1437
    598
    I didn't think anybody even had a compound on their lathe anymore after Robin Renzetti got rid of his.
  19. #14
    Jan 2013
    Erie, CO
    174
    30
    16
    Robin set up is nice and being the machinist he is, it well thought out modification. I prefer to keep my compound, I think it part of what makes the lathe work so well for my application. Granted the eccentric bolt is not the most secure way of mounting the compound. I do a lot of boring and blind hole internal threading, using the sliding compound makes it easier. The other plus to using the sliding compound, I don’t need to dial out and run the chance of dialing back to the wrong number. Since all the bills cut into my profits, I run my lathe conservatively. These lathe were never intended for heavy machining.
