HLV-H lathe needs handwheel/clutch gears replacing
Results 1 to 2 of 2
    Mar 2014
    United Kingdom
    25
    Default HLV-H lathe needs handwheel/clutch gears replacing
    Hi, I need to replace the train of spur gears driving the carriage against the rack and want to know if they are simply a press fit onto the pinions/clutch shafts and so can be detached with a puller or is this all more problematic? Any comments / suggestions much appreciated.
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,890
    1300
    547
    The early ones were one piece . The later carriage gear came with a pinned pinion gear (maybe a later repair).
    The pinion gear having a spigot that fits inside the larger carriage gear shaft
    Bill
  3. Likes Jersey John liked this post
