HLV-H With a Noisy Brake Solenoid
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Apr 2017
    45
    29
    18
    Default HLV-H With a Noisy Brake Solenoid
    Good evening Gentlemen... I just got myself a new HLV-H that has a really noisy brake solenoid. The brake mechanism works perfectly, but when the lathe is running and the brake is retracted, it makes an awful buzzing noise. Just wondering any of you Hardinge gurus out there have seen this before and can get me going in the right direction?
    My guess is that the solenoid is not getting quite enough power and I have a dirty relay somewhere. I was planning to really dig into it tomorrow and I thought I'd try to learn from your experience if possible. Thanks as always for any thoughts or help you can share with me.
    Cliff
    Mar 2007
    England UK
    1,903
    787
    775
    My HLV one was doing this until I cleaned the faces that come together when it pulls in, with some emery wrapped around a flat file.
  3. Likes crpearson liked this post
    Mar 2009
    5,602
    103
    1084
    Mine does not make any audible noise above the machine level noise.
    It should be simple to remove the back grill/cover and then remove the brake cover. Then turn the machine on and it should be clear what is loose.
    I don't use the brake. I cup my fingers around the inside of the hand wheel.
  5. Likes crpearson liked this post
  6. #4
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,989
    1399
    604
    Common problem.
    there are copper wire loops through the lamination of the armature. Their job is to add a phase shift to the alternating magnetic field and thus prevent it collapsing when the current reverses.
    You will find there is a crack/ fracture in the loop(s) . Simple fix is to soft solder the crack , a better fix is to re-weld them (which is anneal them and make them last another few years)
    bill
  7. Likes crpearson liked this post
  8. #5
    Apr 2017
    45
    29
    18
    Thanks guys for your thoughts. This is an old-style machine with the solenoid in the back. I tore the entire thing down and discovered the bolts that should have been holding the solenoid in place were both sheared and the solenoid was very loose in there. I went over everything with a file toothed comb, cleaning and inspecting everything and went out and got some new bolts. I put it back together, but that still didn't solve the problem...
    At least when the spring is installed. Without the spring installed, the solenoid makes no noise, but even slight downward pressure on the lever causes it to start buzzing like mad. Here are the things I've checked:
    - No cracks in the armature (visually anyhow)
    - Cleaned everything carefully
    - Repaired the mounting system
    - Tested line voltage both under load and not. It's 230.
    Any thoughts?
    Cliff
  9. #6
    Mar 2009
    5,602
    103
    1084
    The top end of the lamination stack has what looks like holes on each end. Should there not be a bolt with nut in each of those two holes? These are the two holes
    directly below the 45 degree cut in the lamination plates.
    Or are the laminations held together with rivets?
    A simple thing to try is attach two small C clamps on those two locations I mentioned and see if that reduces the chatter.
    Otherwise I would trust the Billtodd recommendation.
  10. Likes crpearson liked this post
  11. #7
    Apr 2017
    45
    29
    18
    Good eye!!! I checked that out and as far as I can tell those homes have never seen a bolt. They seem to be welded or otherwise bonded together. I clamped them and the noise continued.
    The total resistance in that coil is 43 Ohms. I’m no electrical engineer, but that seems reasonable to me.
    Here are some photos. I polished the contact points a bit but I’d anything it made the noise worse.
  12. #8
    Feb 2009
    1,989
    1399
    604
    repair the copper loops in the moving part.
  13. Likes crpearson liked this post
  14. #9
    Mar 2009
    Eureka, CA
    4,041
    872
    1495
    Are you aware you can buy a brand new one for $135 and be done with your buzzing contactor forever. Your pictures show a unit that is completely worn out.
    Stuart
  15. Likes crpearson liked this post
  16. #10
    Apr 2017
    45
    29
    18
    Quote Originally Posted by Billtodd View Post
    Thank you Bill! I don't see any copper loops at all in the plunger. Are you referring to the copper loops in the part below? I didn't see it at first, but there actually is a very small crack in one of those loops on the corner. I will weld it up tonight. Thank you again for your help!
    Stewart, I would probably buy a replacement at that price. I was under the impression they were a good deal more expensive. I saw someone who was quoted almost $600 from Hardinge. Would you mind sharing your source with me?
    Thanks guys!
  17. #11
    Mar 2009
    Eureka, CA
    4,041
    872
    1495
    I may have led you astray..I went back to the web site I had found that listed that GE solenoid and realized the $135 was for the coil ONLY..oops!
    Regardless, here is the link, maybe they can be some help finding a repair part. Sorry for the false lead.
    Industrial Solenoids |GE Renewal Parts from PSC
    Stuart
  18. Likes crpearson liked this post
  19. #12
    Mar 2009
    Eureka, CA
    4,041
    872
    1495
    Have you seen this thread? The picture and suggestion in the last post look somewhat encouraging.
    HLV-H brake solenoid with open coil
    Stuart
    Edit. Looky here! https://www.ebay.com/p/DORMEYER-LAMI...NNB/1601560024
  20. Likes crpearson liked this post
  21. #13
    Mar 2009
    5,602
    103
    1084
    Quote Originally Posted by crpearson View Post
    Those are the ones.
  22. Likes crpearson liked this post
  23. #14
    Oct 2010
    Dewees Texas
    2,659
    29
    783
    It is probably just the laminations vibrating in the "iron" cores. I would think a wicking grade Loctite would get between the laminations and keep them from vibrating. After applying the Loctite put it in an oven at 200F for an hour to set the Loctite so it does not get into any moving parts.
    Or just ignore it, it is not hurting anything.
  24. Likes crpearson liked this post
  25. #15
    Apr 2017
    45
    29
    18
    Quote Originally Posted by atomarc View Post
    Stuart
    No problem. Actually that link was quite useful as I called them and they can supply a complete solenoid. That's the good news... Bad news is it's an 18 week lead time with a $475 bill. Thank you for the link to that other thread. I will investigate going that route.
  26. #16
    Apr 2017
    45
    29
    18
    I repaired the crack in the copper loop, but the noise continues. If anything it's worse. I'm wondering if this solenoid is just plain worn out???
  27. #17
    Apr 2017
    45
    29
    18
    Quote Originally Posted by FredC View Post
    That's an interesting idea. If all else fails and I wind up ordering a new part, I will give that a try. Thanks for the idea!
  28. #18
    Mar 2009
    5,602
    103
    1084
    Something dented the corner (upper left) in first pic. How the copper ring got damaged can be to mishandling or use. Why would the shape be altered so much in normal operation?
    Your text said that to fix you would weld the ring. On or off the metal lamination stack?
    I am not sure how it is done on a machine. But my thought would be to get a length of copper wire and possibly file it down to square cross section.
    Then bend it around the form it is to be installed on. Then remove the wire and solder or braze the ends together. Press the ring on the stack.
  29. #19
    Apr 2017
    45
    29
    18
    I suspect that the damage was caused by the broken bolts. When I got the machine both bolts that hold the solenoid in place were sheared off and the device was flopping around inside its housing. I suspect it engaged at a strange angle and the strike from the plunger deformed the copper loop, cracking it.
    To test the fix I soft soldered a copper wire bridge between the two corners of the loop. I'd planned to weld it had it worked. I could remove the loop and attempt to form new ones. The do not appear to be appreciably insulated from the laminations in any way.
  30. #20
    Sep 2009
    Apex, NC
    1,567
    773
    The laminations do look loose in some of your photos. As a previous poster mentioned you also might try slathering with loctite or other appropriate adhesive, and clamping/bolting together. I guess you've checked to make sure the winding isn't shorted at 43 ohms.
