How to connect servo's to simoreg for Hardinge HXL.
Likes Likes:  0
Results 1 to 6 of 6
    Jun 2019
    NETHERLANDS
    18
    Default How to connect servo's to simoreg for Hardinge HXL.
    I purchased a Hardinge HXL years ago. I replaced the simoreg and servo's with new drivers and steppers because the control could not handle the interface to the simoreg. I kept the simoreg and the servo's and now I like to re-use them for a small project. I got the documentation for the simoreg but I can not find any documentation for the servo's. The servo's are branded General Numeric HU5040-0AC02-Z and have 5 wires. One of the them is earth (yellow/green). The others are: 2 black, one blue and one brown. The wires are also very hard and brittle. I like to replace them but they are probably hard connected in the servo. Maybe some one has a wiring diagram with color indication how to connect the servo's to the simoreg or has experience with replacing the wires for the servo's. Thankx for your support.
    Regards Rene.
    Oct 2010
    Dewees Texas
    2,493
    28
    705
    I have reprinted HXL and CHNC maintenance manuals. Just checked both and they have wire color and numbers for switches and other electrical parts, but I saw nothing on the servos or the simoreg.
    Any other name they could have called them?
    Jun 2019
    NETHERLANDS
    18
    I also have a manual for the simoreg. It states L1 and L2 for the servos. But it contains no colors for the servo. I don't know about other names....
    Oct 2010
    Dewees Texas
    2,493
    28
    705
    There is one other site where you might get some help. the cnc zone dot com they seem to have a lot of builds going on there. Do watch for CHNC info as both machines were related and shared at least some parts.
    Jun 2019
    NETHERLANDS
    18
    I took the servo apart for cleaning. The wires can easily be replaced. The servo has 4 brushes. 2 brushes are connected to a black wire. These brushes are on opposite sites. The other 2 are connected to the brown and blue wire and are also opposite sites. Most likely I have to combine some wires. Any suggestions?
    Oct 2010
    Dewees Texas
    2,493
    28
    705
    I do not even have a clue. If I could find the right page in the manual I could photo copy it. Right now I do not think the info you need is in either manual. Try the CNC section (top) in Practical Machinist section or the Zone. Mostly manual machinists watch this Hardinge/Bridgeport section.
