How is "high-low speed clutch control" used?
Likes Likes:  0
Results 1 to 5 of 5
    Dec 2017
    Rhode Island
    212
    8
    Default How is "high-low speed clutch control" used?
    It's the lever on top of the BP (series 1 step pulley)which moves a ring 90 degrees. The machine has a back gear lever lower on the head so what is this "hi low" clutch thing used for?
    Did a search but didnt find much...
    Jul 2004
    Houston, TX USA
    31,220
    Sort of like a back geared lathe, the Series 1 BP gives you four speeds in "open belt" and four much slower speeds in back gear - albeit in reverse (one of the reasons you can reverse the motor)
    Dec 2017
    Rhode Island
    212
    8
    But there's a back gear lever on the side, and that hi-lo clutch on top. Do you disengage the top clutch, flip the back gear lever then reengage it?
    Jul 2004
    Houston, TX USA
    31,220
    Quote Originally Posted by FlyinChip View Post
    Its been fifty years since I was around a series 1, but if I am anywhere near remembering right, its FLIP the top / ENGAGE back gear and reverse motor
    You can test this before ever running the motor by simply pulling on the belt to see if I was right
    ( and way more than fifty years ago I was a little south of you at Quonset Point - being a Navy person)
    Dec 2017
    Rhode Island
    212
    8
    My Dad served a year at Quonset as a Lt, around 1955 in fact he was paymaster there. I grew up a couple miles from Quonset. Remember all the cool planes constantly flying over. In machinist school last year, my instructor (he's 75) had started there in the early-60's working on F8 Crusaders...
    After the navy bailed in '73, it sat decaying for a while. But now it is RI's #1 industrial park, plus Electric Boat is expanding to build around 40 new subs. Two huge buildings just went up there at EB.
