DocsMachine
Titanium
- Jan 8, 2005
- Southcentral, AK
I had to take the motor for my HSL apart in order to replace a bearing. And as I'll be running this machine off a VFD, I'd like to disable, if not remove, the brake solenoid and mechanism. (It comes out intact, and can be reinstalled if ever needed.)
What I don't know is the wiring. The two connections to the brake solenoid are thoroughly tied into the windings:
I'd hoped that it was just going to be a case of them tied into the pigtails that connect the windings in the junction box, but this is pretty well built-in.
Now, I'm assuming- and yes, I know what that acronym stands for - that since the solenoid is a winding, basically just a coil of wire, that I can pigtail the ends of the brake connection together and the motor will still work?
I'd like to keep the wires in place and capped, so that if I or some future owner ever decides to put the brake back on, it'll be a simple drop-in job. But obviously I also want the motor to work, too...
Any solid insight? I've got a day or two before the paint's dry, so no rush, but I'll need to know shortly.
Thanks.
Doc.
Thanks.
Doc.
