tonlin
- Apr 13, 2012
- Wisconsin, USA
Can anyone familiar with this model tell me where to find the serial number?
TJ
TJ
"Next job is see if the motor is the original three phase." That means look at the plate on the motor.
Larry
Light and mirror works in many cases. There is a panel on the back of the cabinet to give access to the motor.
But it is pretty easy to tell a three phase motor from a capacitor start single phase motor without seeing the name plate.
Larry
Aha!! I will take a closer look...I think the access panel on the back is covered by the hanging converter system so I will remove it to see if I can get at the motor from the back. Otherwise, its smoke and mirrors time!
How do you tell a three phase from a "capacitor start single phase motor"? By the capacitor cover sticking up off the main body cover?
Thanks, Larry.
TJ
From post #9, as edited a few minutes later, but not re-read by you: "But it is pretty easy to tell a three phase motor from a capacitor start single phase motor without seeing the name plate. Capacitor housings are large, much larger than a junction box, and easy to see, but can be on top or on one side of the motor housing."
Three equal size transformers means the three phase voltage is being changed.
Larry
Lost, indeed. I said, "Three equal size transformers means the three phase voltage is being changed." I thought it was obvious that the three transformers need three phase power in.
I can almost remember back when I bought my first three phase machine and had to figure out all this stuff. It was around 1978 and I had had electrical engineering classes in school, but they did not prepare me for building my own phase converter and other practical aspects of machine wiring. What seems obvious now was all mystery then.
Larry
...Pick ONE:
1. I have a high voltage (460 volt) 3-phase motor being transformed to low voltage (240 volt) 3-phase.
2. I have a 3-phase motor being transformed to single phase.
3. I have neither of the above.
I am hoping this approach will help you get through to me. Regardless, thanks again for trying to educate me, sure appreciate the effort.
TJ
Yes, I would put a 240V three phase plug on the lathe and run a smoke test. Actually, you can do some testing with an ohmmeter on the existing plug first just to check for shorts and short to ground errors. You do have fuses/overload relays on the lathe, right? You have a 50-50 chance of getting the rotation direction right the first time.
Larry
Notice
