J Head Step pulley Low gear not working
Results 1 to 13 of 13
    Jan 2013
    11
    Default J Head Step pulley Low gear not working
    I have a J head with the step pulley. I'm unable to switch to low gear mode. The cam ring does not move to the low position and hangs up about an inch before the end of travel. I noticed that one of the screws (cam ring pin) is missing from the cam ring. Therefore it's only lifting on one side so it may be binding?
    What I find suspicious is when I move the lever to engage the back gears the quill will not turn at all. Move the lever back to high gear and the quill moves just fine. Seems stuck. I've never had this mill in low gear so don't know if that is normal or not. I understand that diagnosing these issues over email is near impossible but would like to know about the stuck quill before I order parts since there may be a larger issue in play here.
    Should I be able to turn the quill by hand when back gears are engaged? I can in high gear so I suspect something else may be going on.
    Mar 2009
    5,333
    97
    1013
    Quote Originally Posted by caprio View Post
    That should be corrected first. The OD of the thread is .245 and it's 32tpi. The length of the thread is about 1/4". The head is round and elongated with a allen head.
    You could turn down a allen screw and thread the end. Use the one you have as a guide.
    Jul 2009
    Munster, In. USA
    2,384
    492
    740
    Some diagrams.
    j-head-1.jpgj-head-explode.jpgstep-pulley-partial-view-.jpgj-head-hi-low.jpgj-head-parts-list-1-50.jpg
    If the threads are stripped in the bearing cartridge for #32 pin then new holes should be drilled and tapped. The housing has to come off and the bearing cartridge will need disassembly to do this. Look for the tiny set screws that lock #32 pin in place before removing the pin. Failure to remove the set screw results in stripped pin threads.
    #4 bearing locknut has right hand threads. The two holes in the face are ideal for a face spanner tool, 5/16 pins. If these holes are shot drill two new ones to suit.
    John
    Jun 2013
    Northern Il
    1,364
    711
    1257
    You do need to fix the missing bolt issue but do you know that you also have to shift the backgear handle on the right side of the head.
    If you shift the one without the other, it will cause the spindle to lockup.
    Mar 2009
    5,333
    97
    1013
    I removed the set screws and have no regrets.
    Jan 2013
    11
    Thanks for all the feedback.
    I did get the unit disassembled. I think the problem was the spindle pulley bearing sleeve was stuck in the housing.
    It did not move up and down or even turn freely. I had to remove it with a dead blow. I'm guessing previous owner hadn't used low gear in ages and the grease got old and sticky.
    Whats really odd is the sleeve doesn't fit easily in the housing even after cleaning it up. Went over both surfaces with steel wool and filed the burrs off. I would think that the bearing sleeve should drop it fairly easy but still be a little snug with no play.
    I was considering drilling new holes for the two cam ring pin's or trying a heli-coil to repair the threads. I believe the cam ring pins are 1/4-32 and am not finding a thread insert of that size. Probably the best approach is to just purchase a replacement sleeve. H&W has them for $138.00. I'm hoping the new one will drop in without the size issue.
    Have any of you seen the issue with the bearing sleeve not fitting back into the housing? Just doesn't feel right to have to wet sand the parts to get them to mate properly.
    P.S. Just saw a thread insert kit on Amazon for 1/4-32 but it's over $100! For that price I should just purchase a replacement part
    Jul 2009
    Munster, In. USA
    2,384
    492
    740
    Drill and tap for new cam ring pins.
    Dressing the bore I.D. and the bearing cartridge(sleeve) O.D. can be tedious. I have had to knock them out with a deadblow and then dress the high spots. It might help to drill and tap first and then fit the cartridge. Check the I.D. - O.D. dimensions for out of round. When properly fitted the cartridge should slide up and down with finger pressure. Expect that the housing has more defects than the cartridge and that a new one will be just as tight until the housing bore is cleaned up.
    Regards, John
  8. Likes JohnEvans liked this post
  9. #8
    Jan 2013
    11
    Just wanted to update you all. After closer inspection of the sleeve it looks ike someone had tried to repair it once before.
    I found the missing cam pin had a thread insert in it which had failed.
    I ended up ordering new parts from H&M. Replaced the assembly with new including a new set of bearings.
    The sleeve dropped right in (a little wiggling a gentle persuasion).
    Re-assembled and it's working as designed.
    Thanks for the help.
  10. #9
    Jan 2013
    11
    Oh, I did have one follow up question.
    What sort of grease/oil should one use on the sleeve and housing?
    Seems like grease would be a little much since there is so little clearance. And could get gummy after a spell
    I opted for just a little WD-40.
  11. #10
    Sep 2009
    Phoenix,AZ
    1,837
    2804
    472
    WD 40 gets gummy also,use spindle oil same as head bearings use.
  12. #11
    Jul 2009
    Munster, In. USA
    2,384
    492
    740
    Quote Originally Posted by JohnEvans View Post
    Right! WD-40 dries out and leaves a sticky film.
    Mobil red synthetic grease is a nice assembly compound and thins easily with oil.
    John
  13. #12
    Jan 2013
    11
    Oh great. Looks like my choice was a bad one using WD-40
    I ordered some spindle oil (VELOCITE SPINDLE OIL #6) as suggested.
    Should I disassemble, clean and re-lubricate or is there an easier way ?
  14. #13
    Jul 2009
    Munster, In. USA
    2,384
    492
    740
    The bearing cartridge can be lightly oiled from the top rather than do a tear down.
