bmklawt
- Jul 30, 2004
- Holland, MI, USA
I have a Lagun FTV-2 and the parts book says I need 2@ 2MM207WICRSUL bearings, This is what I think I've figured out.
2MM: Super Precision ABEC 7/ABEC 9(ISO P4/P2) low contact angle 15 deg
207: 200 Series Light, 35mm X 72mm X 17mm
CR - Phenolic Outer Land Riding Cage
WI: Angular contact-low shoulder on outer
SUL: Flush-ground single bearing, light preload
Can I use a 2MM207WICRDUL which I believe is the same part just sold in pairs.
Also does it matter if I go medium or high preload bearing.
Also at the top of the spindle cartridge it calls for a 6206 bearing does this need to be a ABEC 7 bearing also
Thanks for you help,
Bruce
Bruce
