M head / r8 spindle swap
JacobC
Dec 10, 2018
Converted my M Head mill to R8 spindle
Anyone wanting any info on this I can help you.
True. But finding a function J head and all the parts to make it work , plus shipping, gets exspensive. I figured this was the easier faster way to have a R8 spindle. And this retains the simplistic step pulley design. Lightweight and easy to move the head around. Draw bars cheap and easy to find.
I spent $300 on my conversion. $150 for spindle used from Ebay. $125 on new bearings with new lock washer and nut. Plus a few hours on the lathe turning the spindle down and grinding new splines. Approximately $25 on inserts and grinding rocks. I found a piece of 4140 tubing to make the spacers out of. Modified the original bearing adjuster to fit the new spindle.
I had a draw bar.
Its pretty much a full day of work to make it fit but well worth the time involved!
Hello i too have 1 m heads and about 5 j heads and 1 cherrying head that i have to used yet and i too was looking into what to do with the M head really good shape and smaller and lighter lbs wise .
I had a draw bar.
So now what do you have? An M head with all of the disadvantages of the M head, 1/2 Hp motor and the ability to chuck up tools too big for that mill. Like me trying to drive a 3" face mill with a J head.
Tom
True Tom but I have the great advantage of cheap plentiful tooling and a really light M head. The light head is so easy to adjust. I can swap the belt around to do just about anything I need to do. I rarely drill holes over 1". I use my fly cutter to bore out cylinders up to 5" diameter. I'm not trying to make a living running a business with this thing. Its for projects. I can make just about anything with this machine. It makes you a better machinist using a low hp machine. Anyone that has enough money to buy a big mill that has plenty of hp. And a VFD, rotary converter, 220/440 or 3 phase at someones disposal makes it even easier for them. Every situation is different. If I had $4000 to blow on electrical wiring I would run 220 to my shop and buy a vfd to run a larger mill, plus I would have to buy another mill that works as good as mine. Yes there is plenty of affordable mills out there but The logistics of it is a pain. This mill is great for what I wanna do. If I wanted to do big stuff I would just take my project to a local machine shop. There's no way to justify me buying a larger mill. Maybe a longer table but If I'm working on things that require drilling large holes or heavy machining on a regular basis then I would just need to open up a machine shop for profit.
Jacob
I had a draw bar.
JacobC-
You make it sound real easy. I applaud your efforts.
This project sounds like it would make a great video
or photo essay. I did not realize that a J spindle
could be fitted to an M so easily (I know you did a
lot of machine work to pull it off). I bet you found
some thinner section bearings. I wish I had more
motivation to explore an "out of the box" project
like this. I just assumed there was not enough
room in the quill. Glad I was wrong. I have an M
head on my 8520 Clausing mill. I may someday investigate
exactly what you did. Any bearing numbers and pics
that you might have would be appreciated by this group.
Thanks-
--Doozer
The "R" head was made for using R 8 collets. No extending quill. Some of the adapters are 5" plus for round rams. They did service .
I like an "R" head for particular mills which suspend the heads by the over arm and its location. The whole thing is upon vertical slides, like the "Nichols" or U.S.Burke #2. That way, the knee and tables' weight don't need ramped up or down. You get to that later.
The fully functioning DRO's tell.
Jacob
Just curious which tooling you couldn't get or make for your M-Head that justified all the work to convert it to R8. I have the BS-7 M-Head and have found all the tooling I need for it with only a couple of exceptions where I needed to get creative. I have up to 3/4 end-mill holders for it. But I can drill using my 1 1/2" S&D bits in a collet all day long without it slipping. And I only have 3/4 HP DC motor driving it that plugs into a 110VAC outlet.
I am glad you were successful with the conversion. Hope you have good luck with it in future.
Best Regards,
Bob
I too would appreciate any info you have.
Looking to purchase an older M-head Round Ram Bridgeport. Would like to swap out for a R8 spindle to compliment all the tooling I have gathered the last couple years in preparation for a mill in my garage.
I too plan to machine and grind my own parts to make this work as you did.
email: [email protected]
