mdi edit rejected
smp4616
May 9, 2015
Has anyone run into this while programming a cobra42 with fanuc 21t? I am just trying to do a simple OD turn and it's throwing this error if I go back into the program to change anything, I can't make heads or tails of it, the gcode is all correct.
Not familiar with the Cobra or the 21T control. With MDI on my 18T control it would take several lines to do it, so I do not even bother trying. Can you turn it in the jog mode? How about just writing a simple complete program using the info from the manual?
If this was no help try in the CNC part of the forum. I know that some use Cobras there, every now and then someone gets a CNC answer here but manual machines are discussed more often than not in this part of the forum.
