Motor forward / reverse switch
Likes Likes:  0
Results 1 to 12 of 12
    Oct 2020
    UNITED KINGDOM
    31
    Default Motor forward / reverse switch
    Hi all
    ive got my machine up and running again almost fully functional!
    i need a new switch alternative is fine as long as it works the same, i cant find one as it seems a bit specialist!
    i need 4 or 5 position
    i currently have
    1.reverse start (non latching)
    2.reverse (latching)
    3.off
    4.forward (latching)
    5.forward start (non latching)
    1 and 5 are linked just the starter circuit, (see pics silver switch) 10.jpg10.5.jpg11.jpg
    has anyone done this before and knows of a switch?
    Apr 2006
    Denmark
    475
    1883
    118
    Looks like Telemecanique switches but there must be many alternatives.
    Some questions come to mind:
    Hole size?
    Number of poles? (pull out the switch, draw a diagram).
    Multiple NO and/or NC contacts?
    Wiring? (see if you can get a BP diagram).
    Once you have an idea of this, get hold of a seller and a switch catalogue.
    Sorry, that`s the best I can do, not having a Bridgeport.
    fusker
    Oct 2020
    UNITED KINGDOM
    31
    so its 22mm cut out
    i have had it out and cleaned
    left 90 degrees -start-(momentary) // left 45 degrees NC (latching) //center NO // right 45 degrees NC(latching) // right 90 degrees -start-(momentary)
    momentary is spring loaded and goes back to right/left 45 degrees
    right or left 45 degrees is in NC state at 45 degrees and 90 degrees either side
    start circuit left and right is looped same circuit
    Jan 2005
    The Netherlands
    6,735
    371
    1969
    What does it say on the old switch
    If it has a number on it do a google search
    Peter
    Oct 2020
    UNITED KINGDOM
    31
    yup ive done that this is the closest i can find, although my switch is 100M-ZAA / CL9PAA
    100M-CA9J by SYLVANIA - Buy or Repair at Radwell
    - Radwell.com
    it is not the same switch and it also comes out at £87.99 shipped to me (uk)
    Jan 2005
    The Netherlands
    6,735
    371
    1969
    Look at the HW serie from Idec
    Peter
    Apr 2006
    Denmark
    475
    1883
    118
    zebbguy, I know I asked for it but I got cold feet, looking at your drawing. I thought I knew enough of american relay and switch schematics but apparently there are holes in my knowledge. I read another PM thread recently about the different and confusing schematic styles and I fully agree.
    However, if you get hold of an U.S. switch catalogue (re Peter) you should be allright, at least I hope so. If not, do return to this forum.
    Regards (shamefaced),
    fusker
    Jan 2005
    The Netherlands
    6,735
    371
    1969
    Idec (like many others)seems to have a system where you can stack several contactblocs eighter NO or NC onto the switch
    So now you only need a switch with 5 positions with a latching action on both ends
    Peter
    Apr 2007
    West Virginia
    1,410
    844
    625
    Ebay has been a good source for me for various used switches.
    Oct 2020
    UNITED KINGDOM
    31
    Idec has some very close switch formats but i cant get one that is momentary and latching
  11. #11
    Dec 2012
    United States
    20
    7
    Looks like the one i have for speed control 5 POS 2 Pole Momentary I am sure you seen this
    Mfr. Part #
    SR2511F-0205-19F0B-E9-N-W-159
    Mouser Part #
    105-SR2511F-25FN
  12. #12
    Dec 2012
    United States
    20
    7
    Or Call
    1-877-DRAWBAR (372-9227)
