machine aviator
- Oct 17, 2020
I am finding that when I switch into high speed on my HLV, the internal breaker in my WEG motor starter trips. In looking at the wiring diagram, it appears that this action only switches the motor input leads. Does the higher speed take more power or a larger start-up surge? FYI, I have the motor starter in line because my phase inverter feeds both my Bridgeport mill and the lathe through a transfer switch. I understand it is somewhat redundant for the lathe as it has its own power-fail lock out. I could change the wiring to use the starter on only the mill, but I am concerned that the lathe motor may be iffy. Thoughts welcome.
Dave
Dave
