My first vertical mill(Bridgeport)
Results 1 to 8 of 8
    Nov 2017
    20
    Default My first vertical mill(Bridgeport) question on quill
    Picked this Bridgeport mill up last weekend and finally had time to tinker with it. Any input/comments about mill is greatly appreciated. I did hotwire into the vfd on my SouthBend lathe, high/low speeds all seem to work well. I have started to order the few items that where missing along with its own vfd. One question I have so far, is the quill supposed to drift down on its own?
    Dec 2015
    Connecticut
    1,224
    29
    412
    Bridgeports and clone have a power quill feed, make sure it’s not engaged.
    If that’s not what you are referring to, do you mean the weight of the quill causes it to lower?
    Feb 2018
    78
    29
    22
    It seems we are on a similar path. I pick up my 1970 Bridgeport (9x42) tomorrow. My South Bend 13 is up and running. My first Vertical Milling Machine has some binding in the quill and does not inch down on it's own.I haven't had a chance to get to know it yet but the first thing I will do is make sure all the lead screws, knee pinion gear and ways are clean, adjusted and properly lubed. The zert fittings have grease in them. I'll get to work on that as well. Lots of fun stuff!
    Stay tuned, someone will be along. This forum has many very talented and intelligent members. Take some time to read through some of the threads. You will find many great resources!!
    Have fun!
    Jeff
    May 2003
    Iowa
    10,490
    3616
    4286
    James,
    Please change the title of your thread to reflect the question that you are asking or I will lock it.
    What is drift? Do you mean drop without doing anything? When the spindle is on?
    Otherwise, you have a pre 70s, J head.
    JR
    Nov 2017
    20
    When machine is off and power feed lever is engaged quill remains stationary also if quill lock is engaged. If power feed and quill lock are off, quill will slowly drop. As this is my first vertical mill I am not sure if this is normal or something all mills do.
    May 2003
    Iowa
    10,490
    3616
    4286
    clock spring is broken
    If you don't have a manual, get the serial number from the knee and go here:
    KneeMills.com - Knee Mill Documentation
    There are some videos out there that show how to change.
    JR
  7. Likes jhruska liked this post
    Nov 2017
    20
    Hi JR, serial number I came up with is 14654 which I believe to be 1952. I removed the clock spring assembly and when I did the end of the spring did not look like it was hooked on the shaft. I have a pic attached which shows what I am looking at for reference.
    Almost seems like if I where able to hook the spring onto the shaft and rotate the clock spring housing it would possibly tight'en up? Clock spring is weak maybe?
  9. #8
    May 2003
    Iowa
    10,490
    3616
    4286
    OK, you've got a round ram machine that somebody has put a J head on.
    There should be a pin on the shaft that the spring hooks to. Reference page 3-5 of manual 450 (current).
    JR
