Need Help!- Bridgeport 720 Interact with Y-axis drift when in programmatic cutting
num1bryanp
Nov 16, 2008
Idaho
Hello All,
I am having problems with my 1989 Bridgeport interact 720 with Heidenhain 351/355 controller.
After two years cleaning and rebuilding and creating a fusion 360 post, I think I have found why the machine was for sale in the first place.
When programmatic cutting the Y-axis is drifting at a constant rate, you can see on the screen Y changing, yet If I just manually make a cut it is square and Y does not change.
Here is a picture show the problem, the first arrow is showing the drift and the second is showing a manual cut that is square.
Any ideas?
Thanks, Bryan
720 Update
When I was making some more test cuts in the air yesterday and found out it is also drifting in the X direction when cutting in the Y only axis. It will cut a square but not parallel to the table.
Is there machine parameters that may be wrong or need to set to fix this problem?
Video's showing movement in the X direction only, Y only, and a 90 angle. I did my best to sync the include screen information.
In each case, the first file is a video and the second is .h control file. I included the .h file.
Move X
Dropbox - Move X.mov
Dropbox - 5004.h
Move Y
Dropbox - Move Y.mov
Dropbox - 5005.h
Move 90
Dropbox - Move 90.mov
https://www.dropbox.com/s/xc3duikp4ofbofl/5006.h?dl=0
Any ideas on how I might fix this is greatly appreciated.
If you need more information about the machine or need me to do a test please just ask.
Bryan
720 Fixed ROT problem
Hello All,
So the real question was, what can supersede other commands.
Wait for it..... The Touch Probe
Press Touch Probe
Up arrowed to Rotation ent
It was set +2.0 degrees, pressed 0, ent
ROT disappeared... and this problem is put to bed.
Video of fix
Dropbox - ROT fix low res.mp4
Thanks for your help,
Bryan
