Any and all ideas would be greatly appreciated! Purchashed a used older Bridgeport J Head. When I attempted to adjust the head angle left to right as you face the machine, the head of the adjusting worm shaft just spun with no results. Removed the J head from the machine. I could see sveral things: The Quill Housing Adjusting Gear (mounted on the main body of the machine)had it's two mounting bolts sheard off, and the front third of the teeth on the gear were all ground down. Second I could see the worm gear on the J head was all chewed uo and spun freely without the Adjusting Worm Shaft turning. The shaft of the Adjusting Worm Shaft had broken somewhere just past where the set screw holds the shaft from moving inor out. Sooo, the Worm gear has a portion of the shaft from the adjusting Worm shaft all the way through it and part way back into the hole for the entire Adjusting worm shat. In addition, the key in the Adjusting Worm Shaft got all buggered up and has jammed up somehow in the hole making the removal of the Adjusting Worm Shaft the major problem. I was told by one of technitions for Bridgeport to just try prying the Adj Worm Shaft out somehow. The problem is getting under the lip of the bolt shaped head of the Adj Worm Shaft to pry on. I have been able to pry it out about a quarter of an inch, but I can not get a good enough grip to move the shaft out any further. Any ideas on what to do now? I thought about welding a ring to the bolt type head of the Adj worm Shaft to put a bar through to use as leverage point to pry out the shaft. What are your thoughts and ideas? Also I'll have to somehow cut with a small saw type tool to cut the stub of the shaft stuck on the worm gear itself to free the worm to drop straigt down out of it's position. Any ideas here also? Thanks very much for any and all help! If you need more explanation just ask me how to better explain the situation.
