On/Off Power Switch Linkage for Bridgeport Milling Machines
Results 1 to 18 of 18
    Jan 2021
    New York
    71
    27
    Default On/Off Power Switch Linkage for Bridgeport Milling Machines
    I'm looking for a little linkage kit that links to the on/off switch on the side of the head on a manual Bridgeport Vertical Mill. It allows you to move the switch down to near the side of the head where the quill feed is.
    I know they make such a thing - I've seen them in other shops - but have no idea what they're called, so I don't know what to search for! "Bridgeport Switch Linkage" doesn't bring me anything....
    Oct 2005
    21,070
    Quote Originally Posted by TwoWheeler View Post
    Dis ?
    PN 1034-Vs E-Z Switch - Misc. Machine Accessories - Machine Accessories
    Apr 2004
    Modesto, CA USA
    8,409
    1592
    Delta/rockwell jointers used a toggle switch that had a metal toggle with a hole drilled sideways at the end. A piece of stiff wire went up and had a knob up higher. It may have been for forward reverse?
    Most circuit breakers have that hole.
    Bill D
    VINTAGE CUTLER HAMMER Switch Delta Rockwell Drill Press Band Saw Jointer Table - $39.95 | PicClick
    Jan 2021
    New York
    71
    27
    That's exactly it, but this is in the description: (does Not Fit Step Pulley Head) It's only for 2J.
    Oct 2005
    21,070
    Just call them on the PHONE....
    Jan 2021
    New York
    71
    27
    There's a piece of stiff wire going to the switch, now. The biggest reason is that they insist on having the column spacers in all three machines, which makes the switch really hard to reach for a lot of people. (Myself included).
    It's redneck and stupid, but also dangerous because the "off" position can be hard to find - it's really easy to overshoot "off" and hit "reverse", which is the LAST thing you want, when you're shutting the machine off in a hurry. The three of us who use the machine on a regular basis have "the knack" of using this cheesy setup, but we're not the only users.
    Jan 2021
    New York
    71
    27
    Somewhere, my wife is in hysterics at that statement. (I HATE phones). But yeah, I'll have to stoop to that.
    Apr 2004
    Modesto, CA USA
    8,409
    1592
    Replace the switch with a contactor and a remote switch or two to control the contactor.
    Bill D.
  9. Likes TDegenhart, Illinoyance, Homebrewblob liked this post
  10. #9
    Oct 2005
    21,070
    They have a counter....I've...wait for it...."Driven there" ..."parked my truck outfront"...
    and "walked in"...to "speak with" a..."Real Person".
    They have much more than what's on the website.
    Amazing concept.
  11. #10
    May 2002
    South Central PA
    14,554
    2798
    4286
    I'm pretty sure the HQT linkage is what I modified and installed on my Wells Index 40 years ago, for the same reason. Works great.
  12. #11
    Mar 2009
    6,027
    114
    1182
    My mill came with a linkage like that. It can be made DIY by just figuring out a key angles and distances.
    Anyway, I removed the stuff because there is no advantage to have a lever 12" lower.
  13. #12
    Jan 2021
    New York
    71
    27
    Quote Originally Posted by rons View Post
    There is on this machine because they insist on having the 4" column spacer in the machine.
  14. #13
    Sep 2012
    Minnesota
    268
    78
    94
    Could you not just extend the wiring and move the existing switch lower? If you only need to go 4-5" you probably can shift it with the existing wiring. Doing a linkage setup seems way to complicated for something this simple
  15. Likes bsg liked this post
  16. #14
    Mar 2011
    Geneva Illinois USA
    6,527
    2893
    2599
    Mount a electrical box where it is convenient, relocate the drum switch in that box and run a cable to the motor box. much more secure than piece of wire that can be caught in the swarf with unintended results.
    Tom
  17. Likes Mr.M, digger doug liked this post
  18. #15
    Sep 2007
    Northern Illinois
    3,012
    1645
    1835
    Perfect. I've been wanting to move the swith down as it's becoming difficult for me to reach that high, so I ordered one last week This morning I get an e-mail from HQT; they are discontinued and they are refunding my credit card payment.
    Dennis
  19. #16
    Jul 2020
    Connecticut
    If you are still looking for this, I think I have the modified drum switch, linkage and lever from my J-Head BP. I added a VFD and a new control box and removed that original linkage/lever/switch from my mill a while ago. Send me a PM and I can go digging for it, I think I have a pretty good idea where I stored it...
    --Zax
  20. #17
    Jan 2003
    Imlay City, Michigan
    2,181
    124
    244
    Quote Originally Posted by Mr.M View Post
    This is exactly what I did on our Prototrak at work, it has a four inch riser and is larger than a Bridgeport series one......also moved the push buttons for the power draw bar to the same bracket!
    Kevin
  21. #18
    Nov 2007
    marysville ohio
    10,575
    2960
    7297
    KIT? WTF? You have a milling machine, make a bracket to lower the switch. I have done it twice now and it is no big deal.
