mpaalanen
- Sep 26, 2011
- Vihti, Finland
Hi all,
I have an issue with my recently acquired Optimum MF2 mill. It is a Swiss-made Bridgeport-lookalike manual mill.
Unlike the original Bridgeport, this one uses ISO40 fixture in the spindle. As i actually use BT40s from my previous machine the drawbar is uncomfortably short and only engages a couple of turns at most. So i would like to extend the drawbar a little.
The issue i have is that i am unable to remove the existing drawbar. It will lift an inch or 2 but then hits a hard stop and won't lift any further. So far i haven't found any obvious reason for this. Looking up into the spindle cavity reveals no obstacles - there is a clean thread entering the spindle with no shoulder (i.e. no ball or claw mechanisms - just a thread).
At the top of the spindle the drawbar exits cleanly. The previous owner said that there had been some attempts at making a power tool change mechanism. I assume a remnant from that is a keyed bushing around the top of the drawbar. However, the bushing is cylindrical with no flanges of any kind so could not prevent the drawbar from raising out of the spindle. It is possible the bushing is original but the finish does not match so i suspect not.
Could the drawbar be a 2 part component and in such a case, any ideas how to hold the lower part while turning the upper to separate them?
Any other ideas would be welcome as well.
Or if anyone should happen to have a disassembly drawing of the actual machine, that would be perfect. I do have the user manual but the exploded spindle diagram does not show any drawbar at all.
I can provide pictures but they are rather noninformative. The only clue if you can call it that, is that there seem to be some kind of notch or notches in something below the top bushing. Since it is deep inside the spindle tube it is almost impossible to see clearly, much less to get a photo that would show it clearly.
