Refurbishing a couple of HLV-EM lathes... - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Sep 2020
    Arizona
    77
    13
    27
    I took off the tool mount and cross carriage. The carriage came off easily. I think it was the added weight, plus I may have had the engine lift slightly too taught, so as I slid the carriage off, if the engine lift didn't move equally the tension on the straps would increase.
    No damage to the Teflon or bed
  2. #22
    Sep 2020
    Arizona
    77
    13
    27
    Quote Originally Posted by Mark Rand View Post
    ideally, it would be to do a complete inspection, repair and rebuild. I have an idea that the OP is planning to do a grey-paint rebuild...
    You have it correct, to inspect repair and rebuild. I am going to paint them factory gray...trying to decide on the paint type now.
  3. #23
    Sep 2020
    Arizona
    77
    13
    27
    Quote Originally Posted by triumph406 View Post
    So why the need to take them apart? I don't see what your going to accomplish. You risk damaging the teflon on the carriage, you'll have to realign the headstock, etc etc, and assuming your dissambling both lathes your without an HLV for the forseeable future.
    To do a proper inspection and rebuild. Plus a proper paint job back to factory color. I don't like it when machines are painted when assembled, it's hard to remove all of the grease and other stuff from the crevices. Plus, when you paint it assembled all of the joints are filled with paint.
    I have 4 metal lathes, I can do without these two for a month.
  4. #24
    Sep 2020
    Arizona
    77
    13
    27
    Took a few days off, but back on it. Got the bed off of one of them this morning. Looks like the factory color was green, for sure switching it to a factory gray!
  5. Likes rpseguin liked this post
  6. #25
    Sep 2020
    Arizona
    77
    13
    27
    Both lathes are torn down!
    Tomorrow the beds will be removed and degreased with purple and a pressure washer.
    Having issues getting the drain pipe off. I thought about heating it with a heat gun or torch, not sure if any excess oil inside would smolder/catch fire. Any suggestions???
  7. Likes rpseguin liked this post
  8. #26
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,507
    1808
    2765
    Quote Originally Posted by rpseguin View Post
    I believe Hardinge would paint them whatever color the customer wanted.
    Pastel colors including Green, Yellow, Red. And white (my favorite), and possibly black.
    Even saw a light red-pink one once. Wish there were cell phones with cameras back then so I could have a couple pics to share.
    [QUOTE] ]Having issues getting the drain pipe off. I thought about heating it with a heat gun or torch, not sure if any excess oil inside would smolder/catch fire. Any suggestions??? [/QUOTE
    Have the fire department on speed dial.
  9. Likes rpseguin, CaryC liked this post
  10. #27
    Jul 2019
    163
    32
    probably want to freeze the pipe,not heat it....
  11. Likes CaryC liked this post
  12. #28
    Sep 2020
    Arizona
    77
    13
    27
    911 on speed dial, LOL
  13. #29
    Sep 2020
    Arizona
    77
    13
    27
    Quote Originally Posted by pat pounden View Post
    Ill give that a shot
  14. #30
    Sep 2020
    Arizona
    77
    13
    27
    Got them off. Used a tiny bit of heat and a lot of leverage.
    Next step is to degrease and pressure wash the pans.
  15. #31
    Sep 2020
    Arizona
    77
    13
    27
    Beds are off!
    Glad I took them off, now I can do a proper cleaning of the top and insides...a lot of gunk in there after 40 years!
    I spent and hour sanding and stripping with very little success. I decided to send the beds and control covers out to be blasted to remove the paint.
    I noticed that they have different motors.
  16. Likes rpseguin liked this post
  17. #32
    Sep 2020
    Arizona
    77
    13
    27
    Spent the last few days cleaning the first lathe inside and out. I wanted to get it clean prior to sanding, that way oil and grease wouldn't get onto the freshly prepped surface.
    A lot of time with 50/50 purple/water, then a follow-up with simple green.
  18. Likes dkmc, rpseguin liked this post
  19. #33
    Sep 2020
    Arizona
    77
    13
    27
    I decided to lift the motor so that I could clean under the motor mount as well
  20. Likes rpseguin, Stradbash liked this post
  21. #34
    Sep 2020
    Arizona
    77
    13
    27
    It's been a while since I have updated, but the progress is ongoing!
    I got the beds back from the blaster and they looked great, saved me a LOT of time and materials. I did not have them blast the underside as the paint was good. I am sanding the underside edge about 4" in so that I can get good primer/paint adhesion. This area is a little visible from underneath and I wanted it to match.
    The welded corners were no longer smooth so I filled them with JB Weld and smoothed them out. These areas were filled/sanded/filled/sanded until they were smooth. Any filler on this project that was applied to bare metal was JB weld, not bondo.
  22. #35
    Sep 2020
    Arizona
    77
    13
    27
    The chassis and bed were primed using Sherman Williams Kem Bond HS. It is really thick and took a solid week to dry. This stuff is ROCK hard!
    I then sanded everything until the finish was smooth. There were only a few spots which I filled with a couple of applications of professional body filler, sanding in between coats so that they were perfect.
  23. #36
    Sep 2020
    Arizona
    77
    13
    27
    The next coat of primer is applied and I will be sanding it tomorrow in prep for the paint.
  24. Likes Stradbash liked this post
