Removal of the BP Feed Trip Plunger
Results 1 to 6 of 6
    Jan 2016
    Missouri
    332
    78
    94
    Default Removal of the BP Feed Trip Plunger
    I have a Webb Champ 3, but it's basically a BP clone.
    I can't tell whether the Feed Trip Plunger Bushing is pressed or threaded in.
    Does anyone here have any ideas on removal before I go beating on it with a hammer/punch?
    Sorry for the canted photo... I've got the head canted for easier sanding. Trying to restore this mill into good working order.
    Aug 2013
    780
    462
    212
    Is that a crack in the head casting??? And what's going on with the marks on the quill???
    Sep 2006
    Sacramento County, California
    3,417
    1932
    1028
    Quote Originally Posted by comstockfriend View Post
    Hi,
    I have a Webb 4VH, next one up in weight from the OP's. I copied and enlarged the photo and the line appears to be a deep scratch. I believe that the other marks are on the sheet metal sleeve covering the sindle to keep out dirt. That part is replaceable when the head is opened. (Webb P/N 6086). I put a new one in my machine when I refurbished in about 8 years ago. IIRC, it was less than $10.
    Sorry, I don't know how to remove the trip feed plunger. The Webbs are a close copy of a BP except built to metric sizes so if anyone knows about how to remove the plunger on a BP, it would work on a Webb.
    Jan 2016
    Missouri
    332
    78
    94
    No, it's not a crack. Observant people would notice that I said I'm restoring the mill, and would notice that there's scotch brite pads laying on the bed. The mill is being sanded of old paint. What you see on the quill shield is dust.
    Sep 2006
    3,417
    1932
    1028
    Quote Originally Posted by WJ Birmingham View Post
    That will be a great mill once you are done. I looked for a mill for several years before I found the one I have. If you need parts, I have found that the people at Webb in California are very helpful. I would suggest that you order their combined manual and parts book if you don't already have one.
    Jul 2009
    Munster, In. USA
    2,085
    376
    579
    It is a sliding fit, should drop out from gravity alone. It will hang if small debris is in the bore. Clean clean clean the surfaces of the pin and the surrounding area. Flood the area with light oil or since you are painting, Dawn dish soap. Work the pin up and down. Tap from below if needed to get it started.
    John
