Removing armature and bearings on HLV-H carriage power drive
Results 1 to 4 of 4
    Jul 2004
    293
    50
    9
    Default Removing armature and bearings on HLV-H carriage power drive
    I am replacing the 4 bearings in a Hardinge HLV-H carriage power drive. There are 2 at either end of the armature, and 2 in a capsule whose axis is at a right angle to the armature and contains the worm driven gear and the gearbox output gear.
    The bearing I'm having trouble with is the inboard armature bearing, that is, the armature bearing closest to the worm gear.
    Best I can come up with so far is to remove the outboard armature bearing first, and then put a slide hammer on the armature to pull it away from the gearbox. If someone else has a better idea, I'd sure like to hear it. Also, down in the bottom left of the attached picture there are 2 holes in the gearbox casting. The upper small one seems to be a vent for the motor case, but the lower one seems strange: it's bored all the way through to the outside shell of the bearing, but in situ it is pointed downwards so it's not a defunct oiler hole. Anybody know what it was for?
    Thanks very much!
    Dave
    Oct 2010
    Dewees Texas
    2,493
    28
    705
    Sorry, I can not help on the motor. I maybe seeing things but is that rust on the outside of the armature? If so change to cutting oil soon as water based coolants can cause serious damage to the bond holding the turcite to the carriage. If I am mistaken about the rust pardon me, just trying to help where I can.
  3. Likes LowEnergyParticle liked this post
    Jul 2007
    UNITED KINGDOM
    4,931
    2734
    2404
    On my HLV (no -H), the armature and its bearing pulled out of the drive-end housing with firm hand force. If that doesn't work, tap the worm end with a rawhide or similar soft hammer until it does. If you are replacing all of the bearings, you don't need to be squeamish, so long as you don't mar the shaft or the worm.
    As for the holes, They are both drain holes. A small amount of ATF can get past the seals on the output shaft. It helps for that to be able to leak out at the bottom of the motor casing.
  5. Likes Stradbash, LowEnergyParticle liked this post
  6. #4
    Jul 2004
    293
    50
    9
    FredC,
    Thank you very much for noticing the armature's condition and noting that water-based coolants are advised against on the HLV-H. On re-looking at the photograph I did a double-take, and headed off to the shop to look at the armature itself. There is some corrosion on the armature, but it appears worse in the photograph; also, the dark red insulating varnish is slightly deceptive in the photo. I use Mobilmet 404 pretty much exclusively, Thank you very much for the thoughtful heads-up!
    Mark Rand,
    The shaft came out with a few taps of a plastic dead-blow hammer on the housing while pulling outwards on the shaft, just as you suggested. Many thanks! I'm also very glad to know the purpose of those two small holes in the housing. Thank you very much for your assistance!
    Best regards,
    Dave
