Glenn Brooks
- Nov 16, 2014
- Woodinville, Wa
My Bridgeport clone Servo 140 table feed(right hand side drive) lost its power cord yesterday. One of the wires pulled loose from the bottom of the housing.
I can’t figure out how to remove the innards without damaging the parts. I loosened the bottom housing. Took out the four screews, pulled the nut off the drive gear on the bottom. The parts assembly seems to be held in the housing by a spring load of some sort. Won’t come out. Even the plastic drive wheel on the bottom won’t come off the shaft when prying with a screw driver. The parts diagram shows a retaining pin and clip mid way into the housing. But no way to access them. Crazy.
Any idea how to take these things apart?
Glenn
Glenn
