rendragyarrum
- Nov 21, 2017
Hello all,
I have a Bridgeport J head. I'm new to machining and I've been slowly been learning functions and procedures. I most often have to hold longer pieces of steel with two vices. My particular 6" Homge vices are slightly different heights from the base to the bottom base of the jaws. The vices look very similar, but are probably different iterations of the same model. Taken with my height gauge, there's a difference of .036" between the two. Also, I trammed the table front to back and left to right. I know i can level pieces in the jaws to the end mill, but I'd like to be able to rest the material on parallels and be fairly accurate between the two.
My question is, what is the best way to match the height of the two vices?
-Shim plate at the base of the low one is a quick fix
-Machine the height of the tall vice
-Buy new matching vices (maybe down the road)
Thanks in advance for any insight!
- Stephen
- Stephen
