Suggestions for a good BP Z-axis drive?
Likes Likes:  0
Results 1 to 9 of 9
    Feb 2008
    798
    56
    64
    Default Suggestions for a good BP Z-axis drive?
    I have a 1984 step-head with drive on the x-axis only. I don't mind cranking the y-axis but I'm getting really tired of cranking the z-axis. Are there any good z-axis drives out there that won't break the bank, and (hopefully) bolt right up?
    Feb 2007
    Georgia
    728
    34
    Quote Originally Posted by borne2fly View Post
    Servo makes a drive for the knee. It is just like the X and Y axis drives, though somewhat beefier.
    You can also buy an Asian clone of the Servo brand. It is about 60% of the price and will last about 75% as long. If this is a hobby machine you will never wear it out.
    Before we got our VMC's all our mill work was done on knee mills. The Z axis drive is incredibly useful, particularly if you have a DRO scale for the knee.
    The last few Servos I worked on were also Asian, so don't let the American name influence your sentiment for American workers.
    Servo claims their model 200 knee drive is "made" in the US. I think "assembled" is the correct term.
    Apr 2008
    Australia
    77
    I bought mine from here
    150 Lbs Power Table Feed Bridgeport Milling Machine Z - eBay Workholding, Metalworking Tooling, Manufacturing Metalworking, Business Industrial. (end time 30-Mar-10 09:34:34 AEDST)
    My knee power feed is under a lot of strain but still works fine. One turn of the handle of mine raises the table 0.250 were as the Bridgeport's raise the table 0.100 per turn. I have read of blokes breaking 1/2 inch end mills with these type of power feeds.
    I think the servos would be good for industrial use, taking big cuts and being used by everybody.
    These cheaper ones come with the full fitting kit, just like the servo brand does.
    Davo
    Feb 2008
    798
    56
    64
    Thanks for the input, guys. I think I'll go for it, and maybe even get the y-axis drive too.
    Davo, did that thing bolt right up or were there some modifications required?
    Apr 2008
    Australia
    77
    I bought both the Y and the Z from them as well. As you can see from the link, my mill is different to yours so I couldn't use the supplied Y or Z axis extensions because of the tread size, but you will be fine being a Bridgeport clone. I chose to make my own spacers to bolt the power feeds onto the machine, as the holes didn't quite work out, and mine being a different machine and mounts, but could have used them if I really needed to.
    Mine have been on for about 3 years with no problems.
    I had something fall between the knee and the saddle that I didn't see one time, and the power feed stalled, and then wouldn't work. After scratching my head and thinking I'd blown it up, it only needed the reset button pushed, so there pretty robust.
    You will get everything you need for the axis you buy in the kit, with a few extra bits and screws as well. You will get all the shims, keys, track for the limit switch, etc.
    The price for these power feeds over here are $750 eachAU. I bought the Y and Z from over their for $630AU shipped, and that was when our dollar was low.
    This is the mill I fitted them to.
    https://www.machineryhouse.com.au/Pr...tockCode=M161D
    Davo
    Jan 2008
    spokane
    879
    5
    85
    I adapted my Z from a cheapo HF X. Other modifications were to drill & tap the handle to point back so it dosen't get caught or bumped, also reversed the field windings.
    May 2003
    Iowa
    10,492
    3616
    4270
    Jun 2009
    Michigan, USA
    2,193
    3307
    1726
    I bought one of those gizmos that goes in a 1/2 inch drill motor about 8 years ago and love it. I can still easily put the crank back on for fine adjustment of the knee. If I have more than a couple of hundred thousandths to go I slap the DeWalt 18 volt drill on it and let it rip. I also made an adapter that goes in a 1/2 inch drill motor with a 3/4 inch socket on it. I use it on the vised and Y axis nut. I have two old DeWalt 18 volt drill motors with the adapters in them sitting right next to my Bridgeport. Sometimes simple is the best. Also in the 8 years that I have been using it I have yet to burn out a drill motor. I think JRIowa has a point about the knee on your mill having too much resistance.
    Sep 2006
    Lincoln, NE
    336
    7
    The Servo units are great but spendy.
    I see that there are 2) threads of similar nature for BP or clone knee power feeds on the forum.
    Here's what I did for my DoAll mill..... see post #14
    Bridgeport power feed for knee
