ajclay
- May 5, 2011
- Baton Rouge, LA
I purchased a 2hp BP a few weeks ago and going through it from top to bottom. The motor pulley bushings were wiped out! They came out in pieces along with the keys. Never seen any that bad.... The operator must of been wearing hearing protection from the noise!
Anyway, the motor shaft has about .003 ware and the pulley is a little out of round. Needless to say when new bushings a in place there's to much clearance.
I want to grind the motor shaft down a few thousands and bore the pulley out a little to straighten things up, and make a couple of special bushings. I have more time than money.....
I don't know about plastics, but there seems to be several types of Delrin materials available. McMaster Carr has different ones listed..... Acetal, PTFE, and Glass filled...
Which one do you think is the closest to the OEM material? I would suspect the running clearance should be zero or darn close..
Looking for a few good suggestions. I know with a little help from the group I may be able to pull this repair off and save some money.
Thanks for the help.
aj
aj
