VFD for 600v 3ph
Results 1 to 15 of 15
    May 2019
    ALGERIA
    16
    Default VFD for 600v 3ph
    My new to me Hardinge TL lThe is in need of a 220 single ph VFD input to a output of 600V 3ph. Does anyone have a good brand name or source to buy from other than the overseas junk on eBay.
    We beat around the idea of swapping the motor to a 240v 3ph as the VFDs I found are cheaper for that output but then you have to mess with the internal transformers etc.
    Plus Im told Hardinge used a balanced motor for a smoother operation
    Jan 2017
    Washington
    380
    138
    Contact the folks at VFDs.com or Wolf Automation. They will square you away on the right set up.
    Sep 2009
    oregon USA
    44
    9
    The only step up VFD's I have ever seen is 120v 1ph in and 240v 3ph out.
    For higher voltage I think you are going to need to use a step up transformer.
  4. Likes neilho liked this post
    Feb 2009
    CANADA
    Ontario
    290
    61
    44
    I use a step up transformer intended for step down of 600 to 240V, 5000VA rating though about 2500VA is sufficient. This feeds an older Allen Bradley VFD, both purchased used. Only cost about $200 for entire set up from a used parts electrical supply shop. Check with local HVAC shops as they often upgrade drives and keep the old ones.
    Virginia
    31,828
    7561
    9996
    Quote Originally Posted by overkill19 View Post
    600 VAC 3-P is a royal pain in the arse (and worse..), both now and going forward for an application of such low power.
    You should still see if you can find a 2XX Volt motor that's a good swap and JFDI all the rest to bring it into line with more-common Hardinge practice. Hardinge OEM motor if you can find one, but special balancing is no show-stopper - most motors are balanced well-enough.
    Aug 2014
    bainbridge island
    1,264
    264
    300
    run it from a 480v vfd and don't load the motor beyond 75% nameplate torque.
    Virginia
    31,828
    7561
    9996
    Quote Originally Posted by johansen View Post
    ?? Prolly easier to find that class of goods in Red Deer, Alberta than in "Algeria", but still....
    He HAS only a 2XX service. Motor swap means simple dirt-common VFD - or even an RPC and he's at full performance or near-as-dammit.
    No extra transformer. No added external high-voltage rated switchgear and/or protective devices.
    And then there is shock and fire hazard.... 600 V must have made sense where the lathe USED TO live - an industrial environment with utility-mains 3-Phase, almost certainly.
    That no longer applies and is not likely to do, ever again. Why preserve 600 V at extra expense and risk?
  9. #8
    Jul 2007
    UNITED KINGDOM
    5,069
    2910
    2501
    You may or may not be able to find them wherever you are (ALGERIA??), but the Danfoss VLT 5000 series are bullet proof and available for 600V service. They are also protected against downstream switching, so you can just connect the VFD to the lathe's power cable and not have to mess with the controls.
    I feed my 23kVA one from a single phase step up transformer after disabling the 'lost phase' warning for the input and power the entire workshop from it.
  10. #9
    May 2019
    ALGERIA
    16
    We talked about that as a option. But I usually try to spend money once so if its all the same Id rather rig up once and have full range.
    PS tapatalk wont let me put Canada in my profile. It keeps defaulting if I put in USA it defaults to Afghanistan... I hate apps
  11. #10
    Virginia
    31,828
    7561
    9996
    I'd have thot most Canadians were aware they were in "North America", geo-continentally, but NOT in "USA", geo-politically, and above average FIRM about that not-so-minor distinction.
    So WHY would you "put in USA" at all?
    Attempted virtual grudge f**k? Or what?
  12. #11
    May 2019
    ALGERIA
    16
    [QUOTE=thermite;3373585]I'd have thot most Canadians were aware they were in "North America", geo-continentally, but NOT in "USA", geo-politically, and above average FIRM about that not-so-minor distinction.
    ???? I have zero clue as to what u are trying to say ?
    I was curious as to what would it would default to is the only reason I tried USA , I tried Australia as well it flipped to Brazil...
    Just THOUGHT Id try it to see what would happen....simple!
  13. #12
    Mar 2006
    Vershire, Vermont
    2,282
    1543
    733
    Quote Originally Posted by Mark Rand View Post
    .... the Danfoss VLT 5000 series are bullet proof and available for 600V service. They are also protected against downstream switching, so you can just connect the VFD to the lathe's power cable and not have to mess with the controls.
    Didn't know there was such a thing. And I assume it also runs multiple machines, switching on and off. Effectively a solid state RPC. Thanks for the education.
    Damn. Now I might even change my mind about VFD's.
    Any oddities/workarounds to the system?
  14. #13
    Virginia
    31,828
    7561
    9996
    Quote Originally Posted by neilho View Post
    Might want to grab the manual on their current model and see if what you need is (still) supported, first.
    The maker's website lists that older model line as being past end-of-life for sales & support.
  15. #14
    May 2019
    ALGERIA
    16
    I just talked to my local eecole electrical supply. Over they phone they list a 240v 1ph input - 600v 3ph output. $689CAD
    So they do exist. I think she said Square D makes it
  16. #15
    Virginia
    31,828
    7561
    9996
    Square-D - one of my personal "value for money" favourites - is owned by Group Schneider - who ALSO own several other makers, some with superb reputations, as Schneider are fair-decent at their management and technology.
    That said, not all their component companies and products are equally well-regarded.
    Suggest you take the <Model Line ID> as a search term. Something like:
    "problems with <Model Line ID VFD>"
    Page Two:
    Download the manuals. Zoom-in on labels. Determine where the factory is.
    Not just this one. ANY goods where this sort of pre-purchase research is cheap and easy.
