Vfd for j head mill
Results 1 to 6 of 6
    Feb 2016
    Mississippi
    Default Vfd for j head mill
    I put a vfd on my j head mill for the purpose of single phase to 3phase power. I removed the high/low switch because everything I read stated the vfd should be wired directly to motor. My question is how do I get higher rpms. The speed knob works but only goes to about 500 rpm’s. How do I get it where I can use the 500-3200 range. 3a10c492-0248-4cca-946c-2db22b69d83b.jpg
    Jul 2010
    eugene,or
    779
    68
    325
    Kind of depends on how you have the VFD wired. Have you tried shifting it in to high and reversing the motor?
    Teryk
    Sent from my XT1710-02 using Tapatalk
    Feb 2016
    Mississippi
    Yes I have run it in reverse. Call me a idiot but I don’t know how to shift it in high. I am new to milling machines. Have been running a lathe but not milling machine. Thanks for any help.
    Sep 2009
    Phoenix,AZ
    1,657
    2572
    396
    OK Idiot ! LOL On right side of the head towards the lower edge there is a small lever with a label that says "speed range " with low and HI. You should download the free manual before you damage something.
    Aug 2010
    missouri, USA
    303
    19
    Your motor has to be set at its fastest speed and the vfd can slow it down, if you are only getting 500 rpm, then your motor is set at 500 rpm. I hope that made sense
    Oct 2018
    ALAND ISLANDS
    34
    11
    Quote Originally Posted by JohnEvans View Post
    Yup, do some reading, and watch some of the videos on YouTube. Their quality is variable so start with good authors like mrpete222, joe pieczynski, suburban tools, this old tony.
    Tip: when moving from low to hi range use the jog function on your VFD to engage the gear - don’t force it or do it under load. Also, the neutral position between hi and low is useful when you need to rotate the spindle by hand.
    I leave my VFD set to mains frequency and control the spindle speed using the machine’s variable speed drive. I find this kinder to the motor than altering the frequency to change the speed.
    Mal
    AKA The Felsted Skiver
  7. Likes Zap921 liked this post
