What hammer to hit drawbar? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41
    Jan 2007
    Flushing/Flint, Michigan
    10,762
    631
    8670
    Is the brake on, (sort of hard unless you have three arms) .
    Machine in low, high gear or neutral?
    Every B-port style needs a decent dead blow on hand to seat stock in the vise. It also works here.
    BTW every once in a while remove drawbar and lube or antisieze the threads. This gives a fair bit more pull for input torque.
    Lube can also be be put into the collet threads for sort of the same effect but this is SOP I would think. Problem is lube going down to the clamp surface if one gets too wild in application.
    Bob
  2. #42
    Aug 2008
    near Cleveland
    927
    129
    147
    Quote Originally Posted by jim rozen View Post
    Step one, buy new replacement spindle bearings for bridgeport. Step two, before installing them put them on the bench and beat on them with a hammer. Step three, continue hitting them once they're installed.
    If Otto the Hammerman used the machine, all bets are off. With Otto, everything was torque to yield,plus half a turn.
  3. #43
    Dec 2005
    UTAH
    592
    103
    68
    Quote Originally Posted by Edster View Post
    I've been using one of these forever. Works great!
    Hammer 955561 - MSC
    Same here for 20+ years until I sold my BPs. They worked great.
  4. #44
    May 2016
    57
    23
    52
    I made a hammerwrench.
  5. Likes neanderthal mach, Tom A liked this post
  6. #45
    May 2009
    New Jersey
    348
    92
    68
    Quote Originally Posted by Rlschow View Post
    I made one of these as well, not quite as elegant as yours. Took a piece of brass bar, slotted the center wide enough to fit the wrench and bolted it on just as you did on yours. Works great.
  7. #46
    May 2016
    57
    23
    52
    Quote Originally Posted by jbacc View Post
    Necessity was the mother what you call "elegance". I had planned to use the scrap chunk of brass pretty much as found, but the hammer felt a bit heavy. I profiled it to lose weight...
  8. #47
    Apr 2018
    8,873
    4299
    Quote Originally Posted by Cyclotronguy View Post
    Back when I was an apprentice (old guy story) the better North American knee mills (Tree / Gorton & etc.) had shallow taper spindles, typically 9 BS tapers or larger. Suck one of those clean and dry up into a spindle and you'll be boring it out and sending the spindle out for a rebuild (and looking for a new job!)
    Gortons (the Mastermil line anyhow) have a ring on the drawbar that's captured by a hollow nut on top of the spindle. To pop the tool out you just back the drawbar up against the nut so it pushes down instead of pulling up.
    It's a little slower than a Bridgeport but might be nicer on the bearings.
  9. #48
    Dec 2008
    IL/WI border
    3,537
    1282
    1105
    I use a wrench/hammer of this type:
  10. #49
    Sep 2017
    South Carolina
    1,250
    714
    724
    Quote Originally Posted by MichaelP View Post
    The same thing I used for years. Hung on head rotation bolt when not in use.
  11. #50
    Jun 2009
    Michigan, USA
    4,561
    3527
    2462
    Quote Originally Posted by moonlight machine View Post
    I just push the in / out button. There is no B-port accessory that will pay for itself faster than a Kurt power drawbar.
    Yes there is. An adapter that goes in your cordless drill for raising and lowering the knee is much preferred to my Kurt power drawbar.
  12. #51
    Jan 2007
    Central FL
    907
    8
    22
    OK everyone nobody kill me, but I just use the vise handle. Ya know the rectangular part that is a hinge. I give 1-1.5 turns to loosen the screw ( with the handle again) then give it a tap until the collet or holder breaks free and finish loosening. Been doing it that way the last 20 years. Now everyone tell me how I am killing my machine.
  13. Likes CarbideBob liked this post
  14. #52
    Sep 2015
    199
    13
    146
    I just tap it with the handle of the ratchet, which is always hanging right where I can find it. The nut on the drawbar is obviously made out of something harder than the rachet.
    That's about 20 years' worth of dings with intermittent hobbyist use.
    Sent from my Nokia 7.1 using Tapatalk
  15. Likes johansen liked this post
  16. #53
    Mar 2009
    6,347
    124
    1237
    I use these. Won't dent the machine and won't chip the floor when dropped.
    Eucalyptus is heavy and works good. Can be turned down many times. Your post
    reminded me that my current stick is as thick as the handle and time to replace.
