240,000 data points to mill
Results 1 to 18 of 18
    Aug 2018
    Indiana
    8
    Default 240,000 data points to mill
    Yes I'm new to the CNC world but learning the hard way. I have had a unique cylinder head combustion chamber laser scanned and now have a quarter million data points that need to be massaged into a usable milling program. After welding up the seat pockets and all the remaining surfaces to be re-machined back to OEM profiles/ contours, the combustion chambers don't need mold surface finish but can live with a respectable surface finish. The problem I have is 240,000 points wont work due to time and memory. I'm drip feeding into an older Fanuc milling machine with 4800 baud max capacity. Not sure how or what program to post process the points into the best program. I have read about arc fitting, step over cusp calculations, look ahead drip feeding programs for feed rate adjustments and some other ideas. I'm not in the position to purchase a newer machine at this time and need to make my machine work for at least eighteen months, then I may move onto a newer controller/ machine.
    Has anyone been confronted with many data point conversions into a workable program? I know throwing out some of the points can be done but which ones? Is there a best practice post processing method for assisting in doing what I need to do? And can an inexperienced programmer tackle such a humongous program?
    Mar 2015
    Washington
    104
    26
    47
    Quote Originally Posted by [email protected] View Post
    Have you tried knocking down the number of surfaces? I'm assuming that you're trying to machine from a .stl file. If this is the case, you can bring it into MeshLab, which is free to download, and use quadric edge decimation.
    May 2004
    2,493
    885
    1621
    Seems like Laser Scanner guy is out to lunch to me. I've worked on laser scanned 3D parts for a customer. Customer sent hand-made parts off to laser, they scan and then clean up surfaces to some tolerance, then produce a .step file or whatever with nice, easy to machine surfaces.
    I'd ask for that before you tear your hair out.
    Sep 2009
    Apex, NC
    1,434
    716
    Yea, seems the scanner software should take those points and at least turn them into a surface body, commonly STL. I have a dentist friend that has a lab, and desktop scanner they use all the time for creating dental prostheses in their milling machine and SLA. The scanner spits out STL files, with a settable resolution. Heck, there are cheapo home scanners now that are pretty good that go directly to cheapo rapid-proto machines.
    Mar 2015
    Washington
    104
    26
    47
    Why don't you post the file that you're trying to work from?
    Mar 2015
    Washington
    104
    26
    47
    Usually a scanned surface will be a .stl file, a bunch of polygons, made from the point cloud. If the resolution of the scan is really high, you can end up with a huge file, that's difficult to work with.
    The picture is from a scan of a fish, the original file had so many surfaces that it wasn't really possible for me to work with it in Solidworks. I think the OP has a similar problem, but I can't be sure without seeing the file.
    Sep 2010
    Vancouver Canada
    858
    614
    295
    A pro shop should be able to take a point cloud of typical engineering shapes (i.e. not a skull) and turn it into regular features or NURBS (3D spline surfaces) using software like Geomagic Design X.
    May 2017
    Minnesota
    719
    634
    407
    Mastercam, and I'm sure several other CAMs, can put a toolpath directly on an STL.
    Aug 2010
    Minnesota
    1,868
    144
    1373
    Tony talked about doing this to replicate an issue with engine wear to reproduce sounds... Now in his case they actually needed to replicate the surface they scanned.
    Aug 2018
    Indiana
    8
    Default Laser Scanned Date
    Ok fellas here is one of the laser scanned STL programs. Unfortunately I don't have access to the arc fitting process, may need to go back to the scanner. They sell high end post processing software of some kind but didn't offer any assistance. They knew what I was doing and what I would be doing it with. Maybe they were out to lunch on my money!
    Unfortunately the file extension is a X_T format and the system won't let me upload. Tried an export but not being a computer genius, can't figure out what rout to take. What can I convert a X_T file into so it will come through?
  11. #11
    May 2011
    New Jersey
    1,771
    165
    952
    The file extension is a parasolid file. What cam software are you using?
  12. #12
    Sep 2010
    Vancouver Canada
    858
    614
    295
    Can you share the file on google drive or Dropbox? Do you have both the STL and an X_T? Both would be potentially worth looking at.
  13. #13
    Aug 2018
    Indiana
    8
    Figuring out how to use Google Drive. Not easy for analog old timers!
  14. #14
    Sep 2010
    Vancouver Canada
    858
    614
    295
    Good luck, we`ll keep watching the thread. My father's 70-something half sister has been collecting all sorts of information about my grandfather that seems to have been a total mystery to everyone. Anyway she's assembling these scanned documents in an open office doc and uploading to google drive but the files are like 80Megs so it's causing all kinds of problems I'm trying to help her with. I'm sure I can get them into PDFs which will be much smaller but I have to get them to Word first. Arg!!! In some ways it's a similar problem to dealing with your ancient Fanuc...
  15. #15
    Jan 2007
    Flushing/Flint, Michigan
    7,310
    354
    6134
    Slow down.
    For starters a "quarter million data points" is not huge and sounds like your scan source did their job well.
    Every point will be subject to measurement error so these are not absolute numbers
    You need sort of mold finish or better in a head. (duh)
    Unclear, you are are going to profile mill this .... maybe with .010 diameter ball-nose cutters?
    Unless I missed the boat someone else made this. Get the how to go with your reverse engineering numbers.
    You may not have that how but grasping it makes life easier.
    It is interesting to me that you have a a "unique cylinder head combustion chamber"...... Sort of a lifelong quest in both four and twos.
    Screw the making it, I'd love to see this design and it's merits.
    Bob
  16. Likes spam82, snowshooze liked this post
  17. #16
    Sep 2010
    Anchorage, Alaska, USA
    628
    229
    122
    My thoughts...
    I am an old world Machinist, drug kicking and screaming into the new world.
    So 3, maybe 4 years ago, I was still programming in hand-written G-code utilizing canned cycles and loops.
    Then, I went Cad-Cam.
    The very same part went from say... 500 lines of code, to 12,000 lines of point-to-point code.
    My machines didn't have the capacity to even load it.
    Today's Cad-Cam has absolutely no regard for memory.
    Do a memory up-grade, and don't worry over it.
    I can still write the same part in 500 lines... but I don't care.
    The Bridgeport DX-32 control had megabytes of memory.
    I just up-graded it to where it did not care anymore.
    File size these days... don't worry over it.
    What I do miss is being able to read the code through for a quick spot-check.
    A quarter million points... can't do it.
  18. #17
    Dec 2014
    160
    16
    28
    Mastercam will also filter that path. If you make a parallel toolpath in the X or Y direction only it will turn those thousands of points into hundreds of G2/G3 paths.
    You might be able to just use a 3d toolpath driven by and STL with a containment boundry. Then you can skirt around making surfaces from them.
    You really want good short code to drip feed. You might even not have to drip feed if you can filter it enough.
  19. #18
    Dec 2014
    160
    16
    28
    Today's CAM can certainly output very short code.
    Here is a good explanation of how to filter in the XY plane.
    YouTube
