3+2 face milling many faces.
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Sep 2013
    Minnesota
    360
    137
    88
    Default 3+2 face milling many faces.
    What's the best way to approach milling faces, approximately 50 of them, in a 3+2 setup in Mastercam? Having a NX background, I have looked thoroughly for an operation setting that automatically sets the tool axis. It's probably right in front of me, but at this point I need a little help lol.
    NX 1996.XXXX
    MC 2022
    Nov 2014
    Florida
    6,388
    2554
    3164
    Planes
    Plane from solid face. It will put the zero in the center of whatever face you pick, then you can rotate, transform etc from there
    Jun 2012
    Michigan
    6,389
    5962
    4086
    Are they equally spaced to where you can Transform/Translate the toolpath about an axis?
    Sep 2013
    Minnesota
    360
    137
    88
    Quote Originally Posted by Mtndew View Post
    Possibly, great idea, thanks. I need to look at the geometry closer and see what I can do. The part is a large diamond out of acrylic that will be polished to museum quality. I'd still prefer a face milling op that could automatically set the tool axis normal to a face; I have about 50 facets on this part.
    Sep 2013
    Minnesota
    360
    137
    88
    Create a plane for each face?
    Sep 2018
    1,623
    2544
    875
    Quote Originally Posted by Qwan View Post
    yes, you'd need a plane for every tool orientation.
    Nov 2011
    Idaho USA
    210
    6
    42
    As stated you should not need a plane for every tool orientation as these are symmetrical.
    You will need to make a plane for the first cut then use the rotate tool to copy the tool path around to the other faces you want to cut.
    Sep 2016
    Connecticut
    23
    16
    17
    Make a program for one face, retract, rotate 7.2 degrees, repeat 49 times?
  9. Likes Booze Daily liked this post
  10. #9
    Jun 2012
    Michigan
    6,389
    5962
    4086
    What about Multiaxis parallel or something similar?
  11. #10
    Sep 2013
    Minnesota
    360
    137
    88
    Quote Originally Posted by CNC_Chip_Thin View Post
    The part is a large diamond out of acrylic that will be polished to museum qualitY, the facets are all over the place. I might be able to create a handful of operations then rotate tem about an axis.
  12. #11
    Dec 2008
    Arizona
    1,843
    250
    257
    here is something I did in SolidWorks\HSMWorks out of aluminum, it is in 2 halves hence the seam.
    this was a 3 Axis Scallop finish pass with a .002 stepover, don't have 4th or 5th axis.
  13. Likes CNC_Chip_Thin liked this post
  14. #12
    Sep 2013
    Minnesota
    360
    137
    88
    Quote Originally Posted by len_1962 View Post
    Nice work! Creativity to get the job done is paramount!
  15. #13
    Sep 2013
    Minnesota
    360
    137
    88
    Long story short, not wanting to do any sort of scallop path with small stepovers, my part should be finish cut by face milling.
    So, if the faces are non-uniform with the normals are all over the place, to face mill this part I need to create a plane for every path?
  16. #14
    Sep 2018
    1,623
    2544
    875
    probably not for every path, depends on the layout of the facets, you should be able to make a path for say the center face, then rotate that about an axis, one for the face above/below it etc, and rotate them.
  17. #15
    Jun 2012
    Michigan
    6,389
    5962
    4086
    Are you able to share the part file? Or at least a dummy part file? Myself or someone else can probably help you out better.
  18. Likes empwoer liked this post
  19. #16
    Dec 2011
    392
    61
    245
    It's not as bad as it sounds.
    What do the rest of you reckon this would take, time-wise? A couple hours if he's meticulous?
    OP's been pondering this question for 2 weeks...
  20. #17
    Sep 2018
    1,623
    2544
    875
    Quote Originally Posted by Radar987 View Post
    depending on the size of the ball, i could easily have that programmed in an hour or so in fusion. tool orientation is STUPID simple in fusion.
  21. #18
    Jun 2019
    875
    388
    967
    Quote Originally Posted by empwoer View Post
    And in NX.
  22. Likes empwoer liked this post
  23. #19
    Sep 2015
    Ohio
    1,959
    1255
    2107
    Or you could hand write a 20 line program that rotates the A and mills every facet at that angle by incrementally rotating B. Sheesh, sometimes CAM isn’t the answer.
  24. Likes mhajicek liked this post
  25. #20
    Sep 2018
    1,623
    2544
    875
    Quote Originally Posted by Booze Daily View Post
    what you're describing would create a cylinder, not a ball. for a ball, one would need to rotate A/B AND C. if you know all the correct angles, sure, go for it. i know i could do it way faster in CAM
