7 Pocket Types and How They Work
Results 1 to 5 of 5
    Mar 2011
    Clearwater FLA
    1,115
    76
    213
  2. Likes wrustle liked this post
  3. #2
    Jun 2012
    Michigan
    3,705
    3205
    2141
    I use the Dynamic Mill toolpath in Mastercam the most.
    So I guess my answer to your question would be Adaptive?
    Sep 2007
    Washington
    4,609
    93
    1129
    "Parallel Spiral with Clean Corners" in Mastercam, if for no other reason than it makes a cool-looking pattern on the floor.
    Regards.
    Mike
    Oct 2007
    UK
    1,748
    329
    420
    Talking Mastercam here (and this process for ally electronic enclosures):-
    1. Optirough. Select solid, let it run and 90% of the material is gone.
    2. Optirough rest mill (smaller tool) - running from the above stock model and it will take out the rest.
    3. 2D profile - set Z leaving .01mm on base face, and finish profile (shape depending but mostly ramping Z down for continuous cutting) and it finishes the Z level with the one finish path
    4. 2D pocket - finish base standing off the sidewalls (radial say 0.1mm) - straight path as it is usually the fastest for prismatic shapes
    Doing this you theoretically get a 0.01mm step at the bottom of the inside, but it isn't noticeable. And this process works everytime to give good finishes when you're using 6mm cutters that are 50mm stickout etc - still get good finishes with no squeals or diggins through overloading cutters etc.
    Sep 2013
    Minnesota
    166
    24
    29
    Using Siemens NX...
    1) Adaptive Roughing for large parts which have no delicate features.
    2) Follow Part for small parts and parts with delicate features. Similar to your Advanced, I believe, but has many corner and performance options.
    3) Rest Roughing always, also has corner and performance options.
    I rarely use any of the other types because IMO they generally are obsoleted by Adaptive and Advanced. Also IMO, Rest Roughing is simply another step and is not a "type".
    NX 11.0.2
    NX 12
