Anyone Else Having Trouble With HSMWorks FEED OPTIMIZATION
Likes Likes:  0
Results 1 to 8 of 8
    May 2006
    Illinois
    287
    104
    56
    Default Anyone Else Having Trouble With HSMWorks FEED OPTIMIZATION
    I've been trying to get feed optimization to work with HSM for quite some time now. I even had tech support on the line and demonstrated that it doesn't work. He admitted the problem and said he pushed it up to development to be fixed. That was almost a year ago. Still can't get it to work.
    Anyone else having this issue?
    gm
    Jan 2019
    219
    24
    56
    I've not taken the deep dive into seeing why it won't work, but I've tried to post out feed optimazion in fusion (same hsm works AFAIK) and could never get it to post properly. I assumed it was a post setting/issue, but never dove into it as I'm primarily machining aluminum and it's rarely an issue.
    Sent from my SM-G955U using Tapatalk
    May 2006
    Illinois
    287
    104
    56
    Quote Originally Posted by sirAIG View Post
    Well, if you're noticing the issue also then they STILL haven't fixed it!
    I actually had a tech rep dial into my computer and try to run it himself on my machine. He did a simple model in Fusion because he said it was the same engine. He modeled and programmed the toolpath and then looked at the output g-code and the feed never slowed down. Yet another bug.
    I just was wondering if maybe I was screwing up but apparently its still not fixed. It actually is an issue for me because I am doing a lot of cavities in aluminum with 1/8 or smaller endmills which like to snap if you look at them wrong!
    Maybe they'll fix it someday...
    gm
    Dec 2008
    Arizona
    1,807
    233
    249
    Quote Originally Posted by gmoushon View Post
    gm
    Are you using Adaptive Clearing? either 2D or 3D......
    I use this all the time with 1\8 or smaller.
    I use HSMWorks
    May 2006
    Illinois
    287
    104
    56
    Quote Originally Posted by len_1962 View Post
    I use HSMWorks
    The specific problem I'm having is with 2D Contour of a pocket. In fact, before posting, I did a simple model of a square cavity in a block and programmed a 2D Contour of the inside of the cavity...checked the output code and there's no feed change.
    gm.
    Dec 2018
    Arizona
    55
    8
    40
    I use it in F360 all the time and don't have any issues. Primarily for chamfering toolpaths to make sure I don't blow past corners on my older machine when I'm running higher feedrates. I've used it in other toolpath types also and no problem. Maybe the post processor? In the simulation the toolpaths should turn yellow in the corners where it is applying the reduced feed. I'm using the milltronics pp just for reference.
    Sent from my SM-N960U using Tapatalk
    Feb 2007
    Utah
    240
    17
    13
    I just did a quick test in a 2D contour path and a reduced feedrate showed as cb750chris mentioned, as a different color. It also posted the reduced feed rate. To test this, in cam, choose a very large radius, like 1-2" and look to see if it slows down any arc moves.
    if your tool path is represented as a bunch of linear moves, you will need to look at the 'maximum directional change' in the feed optimization field. try setting it to 1 degree and see if any of the linear moves in your path slow down.
    I'm using the fanuc robodrill postprocessor which is likely well sorted out.
    I did find that with 3d adaptive clearing, if you choose 'both ways', it disables feed optimization (you can't check the box to enable feed optimization) so you need to be careful there.
    Mike
    May 2006
    Illinois
    287
    104
    56
    Just tried it again and here's a pic of the simple model. The radius is 0.10". and the cavity is 1.95" square. Tool is 1/8 endmill.
    Making a large radius doesn't accurately simulate the problem I'm having, but I tried a 1" just for kicks and still no go.
    I suppose the post processor could cause the issue but I'm not sure how. It's an older Kitamura MyCenter-0 and I have no issues what-so-ever with posting. IteEven rigid taps without an issue.
    Here's the relevant code that it generates:
    G01 Z0.08 F40.
    Z-0.2375
    G18 G02 X0.8625 Z-0.25 I0.0125
    G01 X0.875
    G17 G03 X0.8875 Y-0.025 J0.0125
    G01 Y0.85
    G03 X0.85 Y0.8875 I-0.0375
    G01 X-0.9
    G03 X-0.9375 Y0.85 J-0.0375
    G01 Y-0.9
    G03 X-0.9 Y-0.9375 I0.0375
    G01 X0.85
    G03 X0.8875 Y-0.9 J0.0375
    G01 Y-0.025
    G03 X0.875 Y-0.0125 I-0.0125
    G01 X0.8625
    G18 G03 X0.85 Z-0.2375 K0.0125
    G00 Z0.6
    G17
    Any angular change beyond 25deg should reduce feed to 10ipm at a distance of 0.100 before the radius.
    Cutting feed of 40 never changes.
