Is anyone using Blender to do 3D modeling? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Jan 2019
    Tennessee
    685
    201
    208
    Punch! ViaCAD Pro v12 just weight and constraints- no force calculations. Easiest cad I have found for organic/artsy shapes and modeling. It renders good enough pictures for clients if you want- not blender grade for adverts and brochures.
  2. #22
    Jun 2020
    Ohio
    64
    5
    22
    I use Blender for subd modeling before importing the subd mesh into Rhino for conversion to nurbs. For that purpose, it's quite good. The workflow is quite efficient once you learn the key commands. I haven't done any animation in it, but I'm sure it's the same way. However, as you've already discovered, for anything needing precise dimensions, it's tedious at best.
  3. #23
    Feb 2005
    Akron, OH
    1,992
    329
    1521
    Many, MANY moons ago I did a lot of work in Lightwave 3D and a little in Maya. The rendering packages are good at what they do, and I did some client visualization work in them. They're usable for that.
    But where they're not that useful for engineering design is they're not driven by numbers. Say you've modeled up that nice wheel, and you have a parts breakdown, a print and a cutlist. Fine. But maybe the next customer needs one three inches smaller, or with a different gear ratio. If you've done a half-way decent job of modelling, in any real 3d package, that's a five minute modification. Change one number, all the rest of the parts update to match. The bolt pattern changes automatically. The cutlist updates automatically. The prints update automatically. Click, click, boom done.
    With a rendering 3d package, you don't get any of that. You do get the freedom to modify things in a much more organic fashion, add detail only where it is necessary, and the animation/deformation options are far, far superior.
    There's a little bit of overlap in things like jewelry and sculpture, because there the freedom a subD modeler allows may outweigh the ability to do families of parts and assemblies.
    I use Keyshot for visualization if I need shinier output than CAD does, or I need to animate. You just pull your CAD assembly in and go from there.
