Arduino Shield CAD-CAM and CNC Software for GRBL 1.1 f
fstmar
Sep 19, 2013
Canada Montreal
This is a professional CAD-CAM and CNC software integrated into a single package that is easy to setup and use. This nicely integrated solution will provide you with all the tools that you need to make your creative design and control your
cnc machine. The CAD (Computer Aided Design) allows you to create simple or complex geometry using the mouse of by entering coordinates. You can also use a picture and transform it to a format that can be loaded and modified. The tutorial videos which shows you how to perform basic and advanced tasks can easily be found under the help menu. The CAM (Computer Aided Manufacturing) is fusion within the CAD. Using the mouse you easily defined the direction and sequence of machining. The CNC (Computer numerical Control) has everything you need to control your CNC and directly execute what was created with the CAD-CAM. The CNC machining is done by clicking one button. You easily switch from CAD-CAM view to CNC view with one mouse click. The CAD-CAM has a guide that shows you what to do next with clear and easy to understand instructions. The CNC provides a graphical and text description on every task that you perform. There is an extented list of pre- defined configuration files. You can select your CNC from that list to automatically configure or enter the configuration parameters manually. It includes an automatic installer for the latest GRBL 1.1f Arduino firmware and a guided setup for the CH340 driver.This combination of design and machine control makes it very easy to start using cnc mill, cnc laser, or cnc xy-plotter machine and make awesome things.
https://routcad.com/software
Arduino CNC A4988 GRBL CAD CAM CNC Mill Laser XY Plotter Software Tutorial Video | eBaypage6.jpgmain_page.jpg
This is a professional CAD-CAM...
Let me stop you there. I think our definition of 'professional' differ. You might have better luck in the cnc_zone in some of the diy hobby forums.
....I can't believe this forum is petty enough to censor the word cnc_zone if typed as one word. :nutter:
<snip>
I think it's more to do with the way the "Google" bubble works.
There's way more of "Them" (zoners) than "Us", so theoretically if there are enough cross links to CNC Zon3 dot something then that skews how "PM forum" can be efficiently data mined. The google search engine is better than the embedded search capability for PM forum. Too many cross links and "We" start to drift into the "Zone's" orbit and then at a certain critical tipping point of cnc z_one dot something references here then we get sucked into their vortex. "We" are less massive in the "Eyes" of Google.
You are physically prevented from writing the whole actual string as it automatically transposes and posts as *******.com
kinda funny.
