Can someone point me in the right direction for removing the stock next to the radiused slot?( on the stepped face)
I faced the stock , did a 2D contour of the whole outside, then attempted to remove the material that forms the step near the slot.
I was able to program the arc, but not remove the material to the left of the cutter.
A second facing setup on the “step” didnt work as the tool over traveled into the good material.
