Best Cad for dimensioning Step & Iges files
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Apr 2005
    Beaverdam, Virginia
    9,114
    1146
    4624
    Default Best Cad for dimensioning Step & Iges files
    I just want something and I don't mind paying a nominal fee for, that I can use to dimension Step and Iges files that are sent to me or I find on RFQ sites for bidding. I have tried a few free viewers, but I don't trust them as I can't seem to get them to function the same every time. It may be me but just measuring I can get different values or nothing clicking on a dimension multiple times. If possible I would like something that on a simple drawing a handful of mouse clicks and you hint print and out comes a dimensioned drawing. Is this possible?
    I need it for no other purpose. For what I do with an extensive library of programs, cut & paste serves my needs well. Any contouring I do is 2d lathe only and I have a trig program I use for that. Just need something to read drawing dimensions on 2-axis lathe work only.
    Sep 2009
    Apex, NC
    1,575
    776
    I've never seen or heard of any such animal that could be "trusted" short of a CAD package, but would also be interested to hear otherwise.
    Dec 2008
    Arizona
    1,761
    189
    230
    Quote Originally Posted by Dualkit View Post
    SIMPLE ANSWER >>>>>>>>>>>>>>> NO
    step and iges are just the surface\face info, nothing more, nothing less, aka DUMB!
    you will have to pick everything and apply the dimensions manually
    download fusion 360
  4. Likes Dan from Oakland liked this post
    Apr 2005
    Beaverdam, Virginia
    9,114
    1146
    4624
    Quote Originally Posted by len_1962 View Post
    download fusion 360
    I understand that part. I just want the simplest for picking and applying. Some I have tried don't seem to work very easy.
    Nov 2007
    canada
    737
    100
    418
    This could be done in several different cad/cam softwares. However, you're not gonna be able to get anything off the shelf. There would be some custom coding needed in order to get your desired results. On top of that, as with any automation, cost wise you'll probably only be able to efficiently automate 80-90% of this. Still better than nothing though.
    So, you would need a cad or cam package that does expose the api and specifically the dimension aspect of the package. You would then need someone to create the application. This could be a simple 4hr or a comlex 80hr job. Fusion does have api exposed but I don't know if the dimensioning is part of that. I have not spent much time automating any aspect of it. Could be a cheap way to experiment but keep in mind a custom application only works with the software it was designed for. You couldn't port this to other software.
    Solidworks, Mastercam, etc are all possibilities for an application like this as well. Probably not worth while to purchase one of those to experiment with but if you already have a seat it's definitely the path to go down.
    Apr 2005
    Beaverdam, Virginia
    9,114
    1146
    4624
    Maybe I should rephrase the question. If you want to dimension IGES & STEP files with the most ease and reliability for the buck, what would you choose? I have no other uses for whatever I buy. As far as what software I own. What I use for trig is called "Arm Chair Machinist" I bought it from an ex-coworker who wrote it 30 years ago. Still have the original floppies. I just Googled and found out the guy died this past June.
    Nov 2007
    canada
    737
    100
    418
    Maybe post an example of the before and after so we're on the same page. I was replying to this point you made in the original post
    'I would like something that on a simple drawing a handful of mouse clicks and you hint print and out comes a dimensioned drawing'
    If all your looking to do is calculate angles with trig, there's no need to do any of that when dimensioning in cad. As mentioned above, just go get Fusion and start clicking.
  9. #8
    Mar 2010
    CA
    529
    15
    154
    Fusion360 can do what you need I think FreeCad should be able to do it too.
  10. #9
    Feb 2019
    NETHERLANDS
    22
    Download FREECAD for free, read the manual and find out that if you import a STEP/IGES file you can view or print
    the file as a 2-Dimensions plan, with all different views"Front/Top/Bottom/Angle" including dimensions,
    so to your original question, yes it is possible !
    Jack.
  11. #10
    Apr 2005
    Beaverdam, Virginia
    9,114
    1146
    4624
    Quote Originally Posted by goooose View Post
    What I want to be able to do is open a STEP file and be able to create something similar to a PDF file to work from. Does that make sense? Like in the day when a draftsmen drew up a dimensioned blueprint.
  12. #11
    Sep 2008
    2,125
    1482
    1263
    I still use a very old version of Surfcam, that dimensions acceptably well.
    I also use Cadkey99, that's an excellent package for dimensioning, and simple to learn. Also imports stp and igs files reliably.
    Cadkey might have released at one time a free standalone drafting package.
  13. #12
    Nov 2007
    canada
    737
    100
    418
    Yes, makes sense. Any cad/cam software can do this. Sounds like you don't have any modern cad/cam now so just go get fusion.
    I was under the impression you wanted to automate the entire process of importing a model, apply dimensions to it, and then create the print.
  14. #13
    Jan 2005
    CANADA
    Saskatchewan
    10,234
    1398
    3700
    OneCNC can automatically dimension a model. While it is geared towards CADCAM, I think you can get just the CAD module called Cad Creator. This will also permit you to play with solid modelling yourself. They give you the import convertors for iges, step and solidprt (plus more) and these are updated annually. Probably $1500 for Cad Creator and you should contact them for a trial to see if it suits you. Or find someone who has a version you can play around with. I know that 30 day trials expire way too quick if you don't get around to using them right away.
  15. #14
    Apr 2005
    Beaverdam, Virginia
    9,114
    1146
    4624
    Looks like I have 5 suggestions to look at so far, thanks guys!
  16. #15
    Jan 2011
    Fairfield, PA
    419
    218
    209
    One potential problem would be internal threads. Since there is no feature history in a step or iges file, the part will have a plain hole unless someone went to the trouble to model the threads. You would need the drawing with the thread call-out unless you make an assumption based on the modeled hole size.
    For that matter, external threads too.
    Something to be aware of.
    Bill
  17. Likes wheelieking71, barbter liked this post
  18. #16
    Apr 2005
    Beaverdam, Virginia
    9,114
    1146
    4624
    Quote Originally Posted by Bill in PA View Post
    Bill
    Thanks for the heads up.
  19. #17
    Jan 2005
    CANADA
    Saskatchewan
    10,234
    1398
    3700
    Bill
    Shhh! That's our human secret to prevent AI from taking over. Just imagine that whatever Skynet builds, the bolts aren't going to screw in
  20. Likes goooose, TeachMePlease, wheelieking71, Mud liked this post
  21. #18
    Dec 2014
    163
    17
    28
    I don't think the product exists anymore, but CNC Software sold a Mastercam 2D geometry only seat that would do what you wanted (minus the automation). It was unadvertised did not require a dongle and was only $500. I don't even remember the name anymore.
    Might be worth a call to a dealer to see if they still have a similar product. It was awesome.
  22. #19
    Dec 2014
    163
    17
    28
    FreeCAD can do it, but last time I tried it was too buggy to be useful.
    but free is always worth a shot!!!
  23. #20
    Oct 2007
    SPAIN
    4,247
    176
    98
    Quote Originally Posted by avongil View Post
    Mastercam Design
