Best Cam Software for Mazak Integrex 5 Axis work???
Results 1 to 12 of 12
    Nov 2006
    Indiana
    6
    Default Best Cam Software for Mazak Integrex 5 Axis work???
    I'm in the market for cam software for programming our Mazak Integrex 200 III ST. Would like feed back on anyone who is currently programming and what pit falls we should be looking for. Of coarse regardless which software we decide to go with, a good post will be a must for what good is the greatest software with out a proven post processor. Of course we are looking at the initial cost but just important would be the cost of maintenance moving forward. Your thoughts and commits will be appreciated. Thanks in advance!
    Oct 2013
    Hartford, CT
    184
    115
    58
    If you want to be able to hit the ground running as soon as possible, Esprit is the way to go. They have full post and simulation for Integrexes, closest thing to bulletproof you're going to get. I've heard the full 5 axis is adequate, but not their strongest suit.
    Biggest thing you're going to have to deal with are the older control on a MK3 Integrex. That was back when they were lathe based, new Integrexes are mill based. So that adds some quirks. Then you'll want to be able to handle the subspindle and lower turret effectively.
    I've primarily used NX Cam for the last 7 years. NX can do all that you need to do, but I've never been able to get support the way I would like. I'm switching over to Hypermill, but they don't support multiple turret machines yet.
    The other option you have is getting good 5 axis software for the B-axis head to make subprograms when you need full 5, and using mazatrol for everything else Which is honestly not a bad way to go if you don't mind jumping around in programs a bit. I do it all the time. You can do 3+2 milling in mazatrol pretty easily.
  3. Likes HYPERTUNE liked this post
    Jun 2013
    Oregon
    1,085
    330
    657
    For sure Esprit. They have a good working partnership with Mazak. I will double down on the above post.
  5. Likes HYPERTUNE liked this post
  6. #4
    Feb 2006
    Ontario, Canada
    806
    33
    103
    Whatever you decide, I would suggest having your part cut on your machine with the demo software before purchasing. If the software vendor won't/can't do it, then walk away.
  7. #5
    Sep 2013
    Minnesota
    166
    24
    29
    Quote Originally Posted by CNC Hacker View Post
    ...I've primarily used NX Cam for the last 7 years. NX can do all that you need to do, but I've never been able to get support the way I would like. I'm switching over to Hypermill, but they don't support multiple turret machines yet.
    I use NX for 3 and 4 axis work but I have a few friends who use NX for 5 axis work and they really like it. Our experience with Siemens NX support has always been excellent but we go directly through Siemens and they have high standards for support. If you go with a VAR it can be hit or miss and you might find you have to wait a little while to get a resolution to a problem. Small accounts typically go through VAR's but I've heard that policy isn't written in stone so please don't quote me on that; you'll have to investigate that part for yourself.
  8. #6
    Aug 2011
    Toledo, Ohio
    1,672
    39
    579
    Hands down Espirt or TopSolid. Top solid does does alot of B Axis Mill-Turn type machine tools/
  9. #7
    Jun 2008
    Sydney, Australia
    331
    284
    248
    Another vote for Esprit. Using it to program a Mori Mill-Turn similar to the Integrex and very happy with it.
  10. #8
    Nov 2006
    Indiana
    6
    Has anyone used EdgeCam on a Integrex b/4?
  11. #9
    Nov 2006
    Indiana
    6
    Have you ever used EdgeCam?
  12. #10
    May 2002
    South Central PA
    12,707
    1700
    2861
    Quote Originally Posted by rethinkit View Post
    I've used edgecam for years for 4axis mill and for lathe. A former employee now uses it for HMCs and integrexes. His shop moved from Esprit to Edgecam. If I had an unlimited budget i might pick NX, but for now Edgecam is my top choice. For both of us, getting or creating correct code generators for our machines has been the only real struggle with edgecam. Your reseller will make or break your edgecam experience, and your code generator satisfaction.
  13. #11
    Oct 2016
    UNITED KINGDOM
    41
    5
    16
    We're moving from edgecam to hypermill for that very reason, the posts are awful to outright dangerous.
  14. #12
    Apr 2012
    UK
    20
    7
    90% CAM companies buy in their 5X strategies from Module works
    Partners who work with ModuleWorks CAD/CAM components
    Very few develop their own.
    So they all work round about in the same manner. I used Visi 5X and thought there has to be an easier way. That is when I moved across to HyperMill and never looked back.
