Betcha canīt program this...
Results 1 to 11 of 11
    Jan 2013
    Portugal
    Default Betcha canīt program this...
    Hi,
    Can someone teach me how to program this kind of feed screw for a fanuc lathe with only c-axis?
    I'm a Fusion360 user but it can't handle this kind of machining, I've tried Mastercam and I managed to get the path I was looking for but itīs outputing y-axis wich I don't have!
    May 2017
    Minnesota
    664
    553
    342
    I recommend you post this on eMastercam.com; there are several people there who would walk you through it.
    Sep 2017
    Wisconsin
    416
    27
    220
    Can you post G12.1/G112 Polar Interpolation code to this machine?
    Jan 2013
    Portugal
    Quote Originally Posted by mhajicek View Post
    Thank you I will try it!
    Jan 2013
    Portugal
    Quote Originally Posted by Rick Finsta View Post
    No, first of all I get a warning that the toolpath uses y-axis wich its not defined ( I turned it down in the post ) then it outputs an incomplete g code without the interpolation completely useless
    Jul 2008
    finland
    72
    15
    Easiest would be using C-axis substitution + radial live rotary tool with ball endmills. You could program it using wireframe geometry - no solids needed.
    OR
    Turn it using controlled threading (G32) with, for example, ISCAR round inserts. I made a particular macro for this purpose in my former workplace - no CAM needed.
  7. Likes Mtndew liked this post
    Jun 2008
    30
    17
    Sounds like you need a correct machine definition and matching post.
    Select a lathe C axis lathe Not a Y
  9. #8
    Aug 2014
    California, USA
    41
    6
    32
    Contour, Parameters, Axis Control, Rotary Axis Control, select "Axis Substitution" then radio "Substitute Y axis".
    Oh and make sure your post/machine def has 4th axis enabled...
  10. #9
    May 2013
    Near Seattle, WA
    1,019
    258
    825
    Quote Originally Posted by Zudo View Post
    Hi,
  11. Likes couch liked this post
  12. #10
    Feb 2019
    Alabama
    43
    5
  13. #11
    Jan 2008
    Northeast Ma.
    163
    11
    41
    That is a piece of cake.You don't need a CAM system. Just get a threading tool made and cut it like a thread. If you want to use a C axis use a ball end mill and advance it 1 pitch per rev. multiple passes if you need.
