aldepoalo
Stainless
- Mar 8, 2011
- Clearwater FLA
BobCAD CAM released Version V33
Available in the following languages:
Here are the Top 10 new options BobCAD has to offer.
MachiningCloud Import
Build tool assemblies and directly import them to BobCAD's tool crib or tool library. The new XML import options allows the import of 3rd party tool lists. MachiningCloud is the first partnership to take advantage of this new option making tool library customization easier than any previous version.
Barrel Mills
Barrel Mill Tools are now supported for 3, 4, and 5 axis toolpaths. Standard, Advanced, Tangent, Lens, Taper, Double & Section Barrel Mills are supported and come installed in BobCAD's tool library.
Steep Shallow Operation
Best target steep and shallow geometry with a single toolpath operation. Choose from planar or equidistant for shallow areas. This toolpath engine results in up to 6X faster calculation times.
Probing
BobCAD now supports probing, choose from 41 cycles to setup your tools, set your work offset or in process inspection.
Hole Feature Recognition
Automatically finds hole sizes and depths. Pre populates operations types with rules found in the customizable knowledge base. On the fly edits that allow users to override settings if needed.
Corner Slowdown
Feed rate option to ramp down cutting feeds on all, external or internal corners.
Chip Breaking Cycle
Use with roughing and finishing operations that forces a chip break by tool motion. Adjust the length of cut, time, or length of chip.
Advanced Holes
Design holes in 3D using point locations. User defined hole, counterbore, chamfer and threads sizes.
Align to Coordinate System
Move geometry into position from any orientation using a from and to UCS(user coordinate system) . Great for moving parts to zero that are on compound angles.
View to Active UCS
Normalizes views to the active user coordinate system. Making it easier to view and draw on different planes of geometry.
To see all the new features use this link What's New in BobCAD-CAM Version 33 | BobCAD-CAM
- English
- Spanish
- German
- Turkish
- Japanese
- Czech
- Portuguese
Barrel Mills
Probing
Corner Slowdown
Chip Breaking Cycle
Advanced Holes
View to Active UCS
