BobCad Lathe How to change settings to approach the material from the front of lathe
Likes Likes:  0
Results 1 to 5 of 5
    Jan 2019
    Indiana
    12
    Default BobCad Lathe How to change settings to approach the material from the front of lathe
    Doe anyone know what settings to change in BobCad to allow the tool to approach the workpiece from the front of the workpiece? The default is to approach from the rear and I cant figure out how to change it.
    Thanks for any help you can offer.
    Jan 2005
    CANADA
    Saskatchewan
    10,151
    1367
    3623
    In general terms (non-Bobcad specific) if you are referring to the way that the GUI looks, just change the way you think about it. So long as the axis movement has the correct signs to make proper parts, you're golden.
    You can do this by imagining where you are looking at the coordinate system from as being from above, or below or behind the lathe. After a while your mind will get used to transposition.
    Dec 2002
    Pacific NW
    5,090
    8
    821
    Delete post, misunderstood question at first glance.
    Apr 2010
    Wisconsin
    5,946
    4131
    3596
    Quote Originally Posted by DaleMcMahan View Post
    First, you need to state what version you are running.
    Then, you need to give a bit more info on what you are actually doing.
    Is this an OD profiling cut? A facing cut? An ID boring cut?
    In generic terms, there is a "page" in your toolpath set up that addresses both approaches and exits. And, they are very manipulable. But you need to give some more info to be able to direct you properly.
    HuFlungDung is also correct, in that it is possible that you are dealing with a converted toolpost lathe and not a rear turret lathe. Still, as long as your tools are actually defined correctly and your post is configured correctly, it really shouldn't matter.
    Mar 2011
    Clearwater FLA
    1,152
    77
    227
    Dale,
    Most likely what you are talking about is the position of the geometry and display of the toolpath.
    If you are working on a tool room lathe, the tool post is on the front side of the machine. With BobCAD it doesn't matter if you are on a slat bed or tool room lathe, we position the geometry and toolpath in the same position ( see image above ) and the post processor handles the Z and X values.
    For those users that want to see the toolpath in the " correct position" what I recommend is using a bottom view. This way the geometry and toolpath is displayed like it would be when you are standing in front of the machine. Make sense...
    unless I am missing something here.
