MacsPerformance
- Sep 2, 2020
Bobcam V6
Does anyone else have issues with the geometry auto update ruining all your tool paths, usually by changing the depth to whatever bob-cam defaulted to when you created the feature to start with?
My current work around is to use sketches drawn on a plane that is at the max depth of the feature so it defaults to that depth automatically, however if you aren't starting from Z zero then this still gets messed up. I bounce between the model and the cam side a lot so I get prompted all the time and if I ever hit yes I am losing a ton of time trying to fix everything and make sure I didn't miss anything it changed. I am curious to know if anyone else something better?
I have been using Bob-cam V6 for about a couple months now, and I keep dealing with this same issue and factory seems to either think its not important or doesn't know how to solve it. I talked to tech support yesterday and they said that this issue still persists in V8. At this point if the prompt just didn't exist it would probably be better.
-Andrew
-Andrew
