I recently purchased a lathe with Fanuc 21i control
Need to transfer NC files from Fusion 360
Purchased a USB/RS232 cable, specifically an "EZSync 14C"
Down loaded the driver and the Device Manager says its on COM3 and working properly.
It says this if the cable is connected to the PC and does not matter whether its connected or not to lathe control.
When I post a program I cant find any option for sending to that device or machine?
Obviously the cable is there and seen by the manager but from there its no where to be found?
Mfg of cable says I need "File sharing software"?
I believe I have the control parameters set properly and I am sure there may be additional settings that need to be adjusted but I would think it would at least try sending to machine and give an error?
At least I would know I am on the correct path
What file sharing software should I get?
