CAM Software Choice - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41
    Nov 2007
    canada
    742
    97
    405
    Quote Originally Posted by len_1962 View Post
    I'm guessing it's your WorkNC.....?
    Quote Originally Posted by mhajicek View Post
    Well I know it ain't Mastercam. The license manager doesn't work that way.
    Read post #36 again.
  2. #42
    Jan 2013
    Gilbert, AZ
    6,242
    7928
    7989
    Quote Originally Posted by Mtndew View Post
    That is 100% dependent on the person learning. If you're green as grass it might be, if you already have knowledge of cad and/or cam then you'll be fine. Mastercam has a TON of resources at our fingertips to learn from, if i had to guess I would say it has the best support of them all. But that's just a guess.
    I would believe that now that Delcam isn't the FeatureCAM mothership.
  3. #43
    Dec 2008
    Arizona
    1,748
    178
    223
    Quote Originally Posted by goooose View Post
    ok now I saw it
  4. Likes goooose, Chris59, mhajicek liked this post
  5. #44
    Feb 2006
    Ontario, Canada
    828
    36
    111
    I don't know what you're talking about. wink wink.
  6. #45
    Nov 2006
    Jupiter, Florida
    259
    244
    19
    I didn't see it either. Rats
  7. #46
    May 2019
    Michigan
    1,429
    394
    639
    Quote Originally Posted by Dan B View Post
    Are you guys afraid of their mafia?
    C'mon........
  8. #47
    Oct 2011
    Michigan
    138
    13
    47
    Quote Originally Posted by ChipSplitter View Post
    C'mon........
    LOL - the WorkNC mafia.
  9. #48
    Dec 2018
    133
    328
    42
    I would rather use SolidWorks CAM\CAMWorks instead of MasterScamm, JMO, sorry.
    You're a masochist, aren't you?
  10. #49
    Dec 2008
    Arizona
    1,748
    178
    223
    Quote Originally Posted by Fancuku View Post
    only if I use MasterCAM
  11. #50
    Jun 2019
    419
    133
    382
    PSHHHH Please, you want masochism try doing a simple ID milling chamfer operation in NX. I don't think any of the other CAM software out there fights you so hard to not do it.
  12. #51
    Sep 2013
    Minnesota
    318
    107
    72
    Quote Originally Posted by CAMasochism View Post
    That is of the simplest of operations in NX. Training does wonders.
  13. #52
    Jun 2019
    419
    133
    382
    Quote Originally Posted by Qwan View Post
    So simple that NX doesn't even support that type of tool and requires work-arounds and fudging to get it to work, sometimes.
  14. #53
    Nov 2014
    Florida
    4,511
    1731
    2163
    Not sure what version you are using? I agree it is nowhere near as simple as MCX. 2d contour>chamfer> then select tip offset and chamfer amount. In NX (at least what I learned) it was about using the correct tool plane (not sure the actual name), which is really confusing until you grasp how it works (and it took me a long time and I never did quite grasp the concept for getting the correct depths, more trial and error)....
  15. #54
    May 2019
    Michigan
    1,429
    394
    639
    Oh chillun', just use Fusion. They have free support after all.......................
    (j/k)
  16. #55
    Jun 2019
    419
    133
    382
    Currently running NX12. Deburring 2D surfaces isn't much of a problem. ID surfaces that are 2D are a bit trickier because as I said, NX doesn't support back cutting mills. So you have to get crafty in making one up. The real pain comes when you have to deburr 3d surfaces such as the OD and ID of hole and/or slots on a curved surface like a pipe. I've got 2 methods worked out so far that work sometimes, but not always, so I end up just going with FingerCAM.
    They are finally starting to release some built in support for chamfering, years later after just about everyone else, as mentioned in this thread. Still no real word on support for ID work though.
  17. #56
    Nov 2014
    Florida
    4,511
    1731
    2163
    I think I misunderstood then... you mean like ID chamfer as in back deburring. Gotch now, never had to use that in NX. I do it with MCX by using a custom defined tool that I drew up based on inspection with a micro-vu. I just tell it to run a standard 2d contour, and adjust the depth and stock to leave and voila! Back chamfer.
  18. #57
    Jul 2014
    New York
    20
    I use HSMWorks as well, and really like it. Its integration with Solidworks is excellent. Since you're already using HSMXpress, I suggest you keep with this route. The full version (HSMWorks) has been a worthwhile upgrade for us from HSMXpress, both because we sometimes actually need 3D profiling, and also sometimes it is just easier to program using their 3D toolpaths instead of having to draw geometry to make a 2D toolpath work.
  19. Likes len_1962 liked this post
