CAM System for Multitasking Lathes
Results 1 to 8 of 8
    Apr 2019
    SWITZERLAND
    Question CAM System for Multitasking Lathes
    I'm looking for a CAM System for our CNC lathes. The machines are Index C100 with Siemens SINUMERIK 840D sl. The machines have two spindles and three turrets with Y-Axis.
    As a CAD system we're using Solidworks and for our Mills we're using Mastercam. At first I thought we should also get Mastercam for the lathes with a custom made PP. But I've heard there are better CAM systems if you want to program synchronized multitasking.
    At the moment I'm programming with a mix between programming in a text editor, machine cycles and copying milling operations I'm doing in Mastercam. But that's not very efficient and it's really easy to make mistakes this way.
    Important for me:
    Importing Solidwork files
    Set Sync points for the channels
    Being able to use all 4 axis (for chamfering)
    Posting finished programs for all three channels
    Dec 2014
    CANADA
    British Columbia
    1,241
    352
    575
    Esprit is probably the most common software for that sort of work but I’m a Gibbscam user and know it will handle everything you’re looking to throw at no problem.
  3. Likes Chazsani liked this post
    May 2014
    Los Angeles
    410
    75
    Hello.
    I have esprit. I like it because it's not owned by some big company. It does import solid works. If you go the esprit route be sure to get training as sometimes it's bass ackwards in certain things, and the knowledge base thing. Also be prepared for some teething troubles and machine setup problems but that's part for the course.
    Dec 2014
    160
    16
    28
    Quote Originally Posted by rootsandstones View Post
    If you are already a mastercam customer, you want to look at Mill-Turn not the Lathe product.
    It's worth contacting the dealer to see if they have a post yet. I checked and there is one for the Index G220 but not the C100. Your machine might be in progress.
    Mastercam CAD/CAM Software > Solutions > Mill-Turn Solutions > MT
    here is whats new in 2019, it shows the sync manager and machine simulator at the end..
    YouTube
    May 2017
    Minnesota
    722
    640
    410
    From what I've heard from those who've tried to use it, stay away from Mastercam's Millturn product.
  7. Likes Chazsani liked this post
  8. #6
    Mar 2008
    vacaville ca
    377
    45
    86
    Try Esprit, Emco is a partner with them and they have their own 3 turret w/y, 2 spindle and 840d machine, so the post should pretty much be there that style machine.
  9. #7
    Oct 2007
    SPAIN
    2,656
    1166
    824
    Quote Originally Posted by pcasanova View Post
    This is a good call.
    The only other one to look at is Top Solid.
    Partmaker would have been on the list but AutoDevil has killed it.
  10. Likes Billetgrip liked this post
  11. #8
    Sep 2013
    Minnesota
    275
    75
    52
    When you demo with someone, run the VAR through the paces to program a typical part for you and perhaps with a part that is more challenging. Take a close look at the sync manager and also simulation. With good simulation you will not crash.
    This is a sizeable investment so don't feel like you have to narrow down a demo to just one product.
  12. Likes Chazsani liked this post
