I have a CamWorks tool crib which I want to contain tools used for cutting both aluminum and steel. In the TechDB I ONLY have aluminum feeds and speeds programed on the tools used to cut aluminum and I ONLY have steel feeds and speeds programed on the tools used to cut steel. It doesn't appear to matter if the aluminum tools have higher or lower station numbers than the steel tools, CamWorks ALWAYS picks the steel tools. I have the correct material (6061 T6) selected in the SolidWorks Feature and in the CamWorks feature tree for the stock material.
I know I can create multiple tool cribs to get at around this problem (one for aluminum, one for steel), but I don't see why CamWorks gives users the ability to specify material types in both the Tech DB and in the CamWorks feature tree if it is just going to ignore them. Am I missing something?
