CAMWORKS post for a Brother Tapping Center
Results 1 to 12 of 12
    Apr 2007
    Morgantown, WV
    809
    252
    319
    Default CAMWORKS post for a Brother Tapping Center
    I just bought Solidworks 2018 and it includes CAMworks. My intent is to use it with my Brother TC-S2A. I have been incrementally working on getting a post working. Is anybody here using CAMworks with a brother and got a post for it?
    I am stuck for the moment with tapping. The brother uses the G77 cycle for rigid tapping. This cycle uses either J(tpi) or I(pitch) to specify the feed rate. Since i am using inch measurements CAMworks spits out a threads per inch number for metric taps which is how the metric taps are specified in the tool crib too. So for a m3x0.5 tap it spits out F.0197 for the tapping feed rate. I am going to call Yamazen to verify but I suspect the G77 cycle will accept J.0197 for the feed rate. But is 4 figures (.0001) good enough for rigid tapping or does it need to go out to 5 (.00001)? I think on my mazak lathe I specify the thread feed out to 5 digits.
    Any insight that is out there I would be grateful for.
  2. Likes TopSolidCAM... liked this post
  3. #2
    Apr 2014
    san diego
    535
    572
    339
    J = threads per inch
    I = metric pitch, much easier to use. (assuming you control uses the same format as the one I have)
    ie 1.0, 1.25. etc.....
    Frank from Yamazen told me he uses I does not equal inch as a reminder.
    May 2013
    Near Seattle, WA
    1,016
    257
    818
    Quote Originally Posted by eaglemike View Post
    Ya. Always thought that was super logical.
    Our HSMWorks post just looks at how the tool is defined (metric/inch) and outputs I/J based on that.. Never had an issue, but using B00 control, your s2a is probably A00
  5. Likes dstryr liked this post
  6. #4
    Apr 2007
    Morgantown, WV
    809
    252
    319
    A00 control yes. I am still pretty green with this but in CAMworks one of the first things you do is to select the inch or metric tech database. I work mostly in inch so selected the inch. After that it seems to internally work completely in inches. Even metric taps defined in the tool crib are specified with inch pitches and inch diameters. I think i said it wrong above I think the feed would be J50.8 (50.8 threads per inch for an m3x0.5 tap). I assume the G77 will work with such a pitch. I will try it by hand to see. Then try to modify the post.
  7. #5
    Jan 2010
    Gilroy CA
    4,232
    3034
    2246
    Quote Originally Posted by rlockwood View Post
    Its the same for the older controller as well
  8. Likes rlockwood liked this post
  9. #6
    Jan 2010
    Gilroy CA
    4,232
    3034
    2246
    Quote Originally Posted by Pete Deal View Post
    J50.8 will work just fine
  10. #7
    Sep 2008
    Florida
    343
    28
    89
    I've been using Camworks (full version) for 11 years, and am pretty decent at writing posts. I don't have a Brother post, but probably can help you as far as answering questions if you're writing your own. I'll be off until Jan 2, though.
  11. #8
    Apr 2007
    Morgantown, WV
    809
    252
    319
    dstryr: Thanks!
    Rainman: I will be tinkering with this. My head is swimming. If I can't get unstuck I will check in with you.
  12. #9
    Apr 2014
    san diego
    535
    572
    339
    Actually they are all C00. Speedio 450, 500, 700.
    BrotherFrank and I talk about what been there in the past controls. I always have lots of questions, he always has or gets the answer.
  13. #10
    May 2013
    Near Seattle, WA
    1,016
    257
    818
    I meant the OP's control, but envious of all the C's :O
  14. Likes Pete Deal liked this post
  15. #11
    Apr 2007
    Morgantown, WV
    809
    252
    319
    Rainman the genious of CAMworks post processing PM'd me the code and I now have a mostly working Brother A00 post for CAMworks/SW CAM. I say mostly because I know I still have tweaking to do but this gets, i hope, the worst of it. Thanks Rainman!
  16. #12
    Sep 2008
    Florida
    343
    28
    89
    No problem Pete. No genius here. Just have been working with it for a number of years, with much weeping and gnashing of teeth along the way.
