Hello,
I have a Doosan DNM-5700 but am still working on getting a good post to work with my CAD/CAM Setup.
I am using Solidworks 2019 with Camworks 2019.
I am trying to locate or make a CAMWORKS 2019 post to run with a Doosan DNM-5700, with the Fanuc Oi-MF controller
I have been able to post and run GCODE using a generic post called FANUCOM that comes with CAMWORKS
But I have to modify the code by hand to eliminate errors
(it puts G41 T3# on lines when it applies cutter comp, with the # being the actual tool number,
and I need to remove the 3 which is not too bad, not sure why it does this though)
This is allowing me to use the machine until I get a better post configured
They have a few other Fanuc posts as well,
FANUC10M
FANUC11M
FANUC15M
Are any of these posts worth trying? - just curious if anyone has an opinion or knowledge about this
I will go through them and test one at a time, but am open to suggestions as to which of these controllers may be closest to the Fanuc Oi-MF.
I will test them one a time and see if any work correctly.
I tried the DNM-500 post supplied by the reseller and it faulted the controller during the run (on a G41 line)
N99 G41 D1 X1.4498 Y-0.0552 F52;
Alarm: PS0041: INTERFERENCE IN G41/42
I will keep trying to figure this out, perhaps the post is usable if I can fix this error.
I will need to figure this out one way or another, but I am wondering if anyone has been able to locate or develop a CAMWORKS post for the DNM-5700 with the Fanuc Oi-MF controller.
The SOLIDWORKS/CAMWORKS reseller is helping and we will create this together, but it has been slow to get the correct post
The current plan is to learn the UPG (Universal Post Generator), but I am just getting started on learning this UPG.
in the meantime, it would be good to know if anyone has solved this and has this post and if so how did you get it?
Thanks!
Steve
FANUC10M
FANUC11M
FANUC15M
Thanks!
Steve
